Hell yes. For a long time I never used a mouse pad (pretty much since I started using optical mice). A couple of Christmases ago my bro bought me a Razer Destructor, and now I will never be without a good mouse pad.
The worst thing about cheap pads is that they're tiny. If I didn't have a large mouse pad, I would rather go without.
EDIT: this is my mousepad.
no mouse pad. even the large ones are too restricting. I'm a low sens user. I don't know if it works or is needed in vista/w7 but I also use the cpl mouse fix which is supposed to turn off windows mouse acceleration so sometimes I need to make a large swipe if I need to pull a quick 360.
Err... so do you swing your mouse hand about wildly if you play games or something? there's more than a foot of horizontal space on "gamer" mousepads. I barely move my hand more than four inches when I'm doing anything, and that includes snap 180s in CS:S
I use more of an arm movement when I play CS:S. It probably takes two full swipes to pull a true 180. When I did play I would turn with the mouse but I'd have to strafe in the opposite direction at the same time. Sensitivity ~ 1.8 maybe? I've gone as low as .95. That's with the cpl mouse fix.
TF2 I used a higher sens. Quake maybe even higher so I can hop.
i hate mousepads. they soak up sweat and are gross
How come your sense is that low? you have to move a lot more to get an aim on someone.
