Higher horsepower vehicles require looser tolerances. I would think with everybody striving to wring the the last bit of horsepower out of every engine, oil consumption would raise across the board.
this is actually not true....the tolerances in todays engines are actually tighter than ever, it is less friction that is the key to more horsepower and better mileage. this is why todays oils are so much better on the molecular level than oils your dad and his dad.
Mobil One is not what alot of people think it is...especially for the European engines, BMW, VW, Mercedes, Audi, etc
below is some information from an expert in the field of lubrication, Kevin McCartney
For some cars, using conventional API & ILSAC approved oil
of ANY brand and/or ANY viscosity there is no safe change
interval. Even 2,000 miles could get you into trouble and
3,000 miles certainly will.
The most current Mobil 1
product data sheet I have shows that it does not meet the
BMW LL requirement.
1. The current (2/2005) Mobil 1 5W-30 fails to meet the
ACEA A5/B5 or A3/B3 ratings. It previously met the A5/B5
ratings but was thinner (10.0 Cst verses the current 11.3
Cst) than the BMW stuff. The current 10W-30 meets the A5/B5
rating but is significantly thinner at 10.0 Cst (BMW oil is
up around 12)
2. Both the Mobil 1 5W-30 and 10W-30 fail to meet the BMW
LL approvals.
The Mobil 1 "Extended Performance" versions still do not
meet BMW LL approval or ACEA A3/B3 or A3/B4 approvals.
The Mobil 1 0W-40 European formula does meet the A3/B3/B4
and BMW ll ratings but it is a 14.3 Cst SAE 40 weight.
while Castrol does pretty well...
Castrol Syntec 0W-30 is a 12.1 Cst SAE 30 weight that does
meet the ACEA A3/B3/B4 and BMW LL approvals. It is a good
choice for the BMWs that require a 5W-30 or 0W-30. Castrol
5W-30 and 10W-30 are much thinner than the Castrol 0W-30
and Mobil 1 XXW-30s and has the same shortcomings as the
Mobil 1 XXW-30 products.
BMW is using variable valve timing which makes proper
viscosity even more important. So, I'd go with OEM, Castrol
0W-30 or another product that meets similar specs.
1.Most people don't have "normal/schedule A" driving
conditions. 2. Oil service ratings ratings are critical. 3.
Failure to obtain proper oil changes can result in
catastrophic engine failure that is not covered by the
manufacturer.
I doubt that most people (even technicians) will understand
what oil service ratings are and how complex this issue is.
It's a pretty safe bet that when Bubba at the quick Lube
says: Brand X, XW-X0 is the stuff to use, he'll accept that
as a service rating and call it good.
If people (including technicians) could be trusted to
always use the correct service rating and viscosity, then
the Schedule B recomendations that are stretching to 5,000
miles might just be OK as an absolute maximum. EXCEPT, in
the case of the unexpected impact of minor design changes.
Those minor design changes have created nightmares for
owners of Toyota 3.0, 2.2, Chrysler 2.7 (and perhaps 4.7),
VW 1.8T, etc.
Without knowing which engine will fall victim to this
syndrome next, the 3,000 mile oil change seems like cheap
insurance. Unfortunately focusing on the 3,000 mile
interval has another problem. It convinces people that the
oil change frequency is more important than the service
rating. Those engines I listed above have proved otherwise.
Oil service ratings are complicated enough for seasoned
technicians. They are way beyond consumers and Bubba,
Kooter, etc.
My Ex-wife has a Lexus with the 3.0 sludge monster. It is
not a simple decission sorting out the kind of oil change
service to best address her situation(that fits both her
needs and the shop situation without wasting $$$).
Do you go to the highest grade ($$$) oil and extend oil
changes to 5,000 miles? Do you go to oil is half the cost
but still double the conventional stuff and stick to 3,000
mile oil changes? Do you blend 4 quarts of Diesel rated
conventional with a quart of that highest grade group IV
base stock stuf and still stick with 3,000 mile changes?
Depending on who the chosen local oil supplier is and the
OEM recomended viscosity, any of those options could be
very sound. But that article sure as heck doesn't explain
how complicated that decission is going to be for the
service provider.
I don't have all the details but there have been links on
at least one of these forums (TDF I think). Mercedes Benz
(and other Europeans) have more specific oil requirements
for their vehicles. Especially their high performance, TDI,
and vehicles equipped with oil monitoring systems and
extended drain intervals. Many API SL oils do not meet the
required ACEA specs (A3, A5, B4, etc) or proprietary specs
( MB 229.3, MB 229.5, VW 505.00, BMW longlife 01, etc).
Apparently MB dealers assumed that API SL took care of
everything. thats why they lost when they were sued over engine issues, using the wrong oil...
That's easy to believe. Even many seasoned
techs aren't aware of the ACEA ratings. In some cases I
think the issue was just one of a "higher" spec being
necessary for the extended drains. In other cases I think
the higher spec was required no matter what (That may have
been just the AMG performance models). Regardless, MB lost
because it was shown that their dealers were not using the
required oils or recomending the required oils. I've read
at least three different accounts of the situation and they
all seem to agree that the problem was mis-understanding or
ignoring ACEA ratings. The assumption is that the vehicles
were damaged from use of the wrong oils. None of the
accounts I read gave details on that.
I think any API SL probably meets A1 even if it is not
labeled that way (not sure). Many of the others are much
more specialized and harder to meet. IE: It is extremely
dificult to find an oil that meets all of the VW TDI
requirements. In fact VW of America chose to exclude some
of VW Europes requirements because the oils would be too
dificult to obtain here.
I think the API approach to service ratings has created a
problem. API insists on a single current standard that
always remains backwards compatible. That has historically
meant that nobody had to worry about service ratings as
long as they purchased a reputable brand in the proper
viscosity.
But that aint so anymore! The Europeans have taken a very
different approach. Changes in engine and emission
technology and economic pressures of taxes and disposal
fees have resulted lubrication needs that simply aren't met
by a single service rating.
There are 14 generic European service ratings and most of
them exceed API standards. There are also about a dozen
important Proprietary European ratings that exceed API
standards. And, even American and Japanese cars often
require prorietary ratings that exceed API standards.
So, if you select an oil assuming that the current API
service rating is plenty, you fail to meet the needs of
Ford, Honda, most European cars and a few GM, Chrysler and
Japanese cars.
And there are strong indications that a significant number
of the remaining Chrysler 2.7/4.7, Toyota 3.0/2.2, etc are
still underserved by the API standard.
But attitudes change slowly, The general public and most
technicians in America are still selecting oil as they did
when service ratings could be ignored.
