BD231
125watt stock rating + 125 additional oc watts as evidenced by this thread = capable of 250 watts at 4.6ghz. A 4.8ghz OC would go over the 250watt rated gtx 480.
If you want to assume nobody runs these chips through full load situations in their " every day use " I'd say that's a little presumptuous and it's a lot of additional heat you'll have to deal with if you actually decide to do something other than underutilize your hardware. If you're using just the stock cooler it's going to cost you money to OC so I think it warrants some consideration. I buy my hardware to use it, not kill it.
Vishera at stock over an OC'd pehnom, not worth it.
