Improvements? Last I checked an overclocked Vishera uses more power than a GTX 480. Enjoy your chip :thumbsup:
Your comment intriqued me, about an overclocked Vishera using as much power as a GTX480. I didn't think that was likely to be true, but who knows? So, I did some searching... I think your comment is a bit misleading.
According to
Anandtech's review of the GTX480, their test system uses 190 watts at idle. Fire Furmark up and you get 479, meaning the GTX480 uses 289 of those watts, plus whatever it was using at idle. So probably pretty close to the 300 watt ATX limit or whatever it was that was talked about quite a bit.
Also according to
Anandtech's review of Vishera, an overclocked 8350 system @ 4.8GHz users 294.3 watts... for the whole system. Anandtech shows that the system used 74.2 watts at idle, that was with the system not overclocked, though. So if we are generous, and say that at idle 50% of the power is Vishera (probably much less than that) we get only ~260 watts being used by a very highly overclocked and overvolted chip, and likely a good bit less than that as I doubt it uses 37 watts at idle.
Techpowerup measured 205 watts for a 5GHz 8350 and only 254 watts for the entire system with the CPU at load.
I guess I am not seeing Vishera, even when overclocked and given a few voltage bumps getting to bone stock GTX480 levels. Maybe not really far from it, but it wouldn't appear that it is actually using more, there is still a pretty big cushion there. It appears to me that a highly overclocked and overvolted Vishera is more in the lowish 200 watt range. Still a lot worse than Intel chips, but it would appear that it isn't at the levels you suggest either.
