I've never stated my own personal beliefs on P&N but you polite response warrants that I do now..
Sorry K7SN, I don't buy it.
While I appreciate the effort to find common ground, there is absolutely consensus by climate scientists that the Earth is warming and we're the primary cause.
I will agree that we are a
significant cause but I am not ready to concede we are the primary cause. Though my personal beliefs think we are;
I don't have enough research to back up my personal beliefs.
Outside of large (relatively) drop off in the output of the sun the Earth is going to continue to warm. It's just the rate and the impacts that are under investigation.
Sorry I disagree; that solar output the only way and it is not likely to happen. What happens this millennium will influence next; unlikely to cause the extinction of man on this planet even in the next millennium (3,000 to 4,000 AD). My personal belief is that only the future actions of man this millennium could possibly stop a long term gradual decline in temperature; we are still in an ice age epoch.
There are other under-investigated things that cool the earth. Since we haven't reached the levels of CO2 that in the past have triggered
some of the earth's other mechanisms for cooling; I believe nothing has changed but
I used
some of in the above paragraph because (
again my beliefs not back by real science) there is little to indicate the earth is ready for a paradigmatic change in our current chaotic state of climate. That means unless something outside the earth, causes (an large asteroid hitting) or triggers other of the earths mechanism (a dramatic increase ion volcanic activity as an example) we should soon (perhaps within the next two millennium) see large sheets of ice begin to form at the poles, green land and Antarctica. In the next 10,000 years the northern hemisphere again have more ice and
OverVolt's land bridge to Siberia actually will happen. We agree that man's excessive use of banked carbon (Coal and Oil) is a factor. Those carbon sources are renewable but the mechanisms are beyond our control and most likely the time period would include epochs inhospitably to man. My personal beliefs are that we are more likely to get hit by or have another large asteroid pass by close enough to alter the earths orbit is far more likely; hence we call them nonrenewable energy sources.; again their is
Not enough research to back up my personal beliefs, maybe we can find some way to bank that much carbon.
We need the climate of the last two hundred years since that's the climate we've built most of our farms, cities and ports. Significant changes will be very expensive to the first world and devastating to the third world. Not to mention wildlife.
We're already seeing and paying for the effects:
- Overfishing and warming waters have significantly reduced North Atlantic cod fishing.
- Alaska is struggling with the down turn in oil and the added expense to move Inuit villages that are now threatened by climate change
- Florida is having saltwater intrusion problems on ground water due to rising sea levels.
I agree completely, but I also believe with my understanding of climate change that we can't won't have the last two hundred years the next two hundred years. This post is too long to go into the minor triggers of climate change that in the last 200 years have proved that; if you challenge that opinion I'll respond in another post.
So it's great you want to find common ground but to use an analogy, getting a cancer patient to agree to eat better, but it's only by getting them to agree to chemo and stop smoking that they'll have a chance to make it.
Very good point which I agree completely but saving habitat while working in the deplorable political conditions in the US it is the only action I can take to mitigate. We just did a sage grouse initiative by working with the left, right, far left, far right and conservationist
http://www.sagegrouseinitiative.com/ and are working to strengthen such efforts to bring all the players to the table on other conservation issues. That is how I got involved in this thread.
I'm also unsure why you think the climate has been chaotic recently. By historical terms it's been fairly benign since the last ice age which has allowed our growth)
I use 'chaotic state' to describe a complex system which we do not know all the factors. Examples; It was extremely wet in Nevada (151 years a state today) until the 1920's when it got much dryer - climate change that proves were in a chaotic state but we have hovered in one section of that state for the last 11,700 years and the variation to date are not significant; sure the Sahara bloomed and central America (ending Mayan civilization but not Mayans) dried up in that timeframe; not predictable other minor mechanisms made central America wet and the hub of biodiversity; while the civilizations in the Sahara disappeared. Krakatoa caused climate change for several years, a forest fire in Canada caused climate change and not flying planes after 911 causes climate change. These are minor triggers but I can cite those examples and many more. The increase in intensity of weather which changes the amount and duration of water vapor in the atmosphere (BTW: water vapor is considered a greenhouse gas) and the only pending
research can back up my personal beliefs like it is a serious of these minor changes that will lead to the major triggers that have always occurred when CO2 and other greenhouse gases have risen slightly above the levels we are currently at
Please ponder this jpg
https://en.wikipedia.org/....jpg for a quick citation of climate change during the age of homo sapiens (400,000 years); note every time in the past (150,000, 300,000, 450,000 (
Not on graph) we reached that point; the earth brings us back in a slow steady decline that lasts 140,000 years. My personal belief is we were approaching our next ice age long before we started burning coal in mass quantities and all our influences to date have just hastened a natural process; the earth will correct. Again
Not enough research to back up my personal beliefs but I can detail several other mechanism in another post.
My personal beliefs hopefully not subjected to scrutiny in P&N follow: The earth is hotter than it likes and should have mechanisms to cool itself. The action of man will most likely only hasten the triggering those mechanisms. My fear is that unlikely possibility that our (mankind) actions may trigger one of those
other major mechanisms haven't happened in the geologically recent past (
last few million years); what happens then is unknown but doesn't bode well for mankind.
