I have a 3600x with an asus tuf x570 wi fi mobo and a mattrexx 50 case.
Anyways I had a spare never used wraith prism cooler with the stock paste still and used that instead of the wraith spire. Temperatures dropped and it was working pretty good.
However I had to get into my computer and change my nvme drive so I had to remove the heatsink and in doing so I used 99% rubbing alcohol to completely clean the thermal paste off of the prism and cpu.
I ordered two small 1 gram tubes of kryonaut and just put it on tonight. However the temperatures are higher than they were with the stock paste. I used up the whole tube doing the paste three times. I spread it at first, wiped it off then tried the x method, wiped that off then did the line method.
All three times I did this my temps were higher than before. Cinebench r15 would never go above 77 celsius even during five multi core tests in a row. Immediately it jumps to about 83 celsius now. Also my max boost all core clock on everything stock/auto would boost to 4.1 ghz all core prior to this with the fan switch on high now i get 4.03 at best with full speed high setting cpu cooler fan and by the time the benchmark is over I am around 3.97 ghz. I used to get in the 1620's (1629
was the best I ever got) if I had the prism set to high and full speed in bios and even with silent bios and low setting on the prism I'd get between 1595 and 1605 so about 1600 on average. Now I'm getting that with high speed prism and full fan speed and 1550's! when I'm on low prism fan speed and silent fan bios.
What am I doing wrong? Could I have gotten a bit of the old stock thermal compound under the lid in the area where the i/o die and chiplet is on the cpu and could that affect the heat? Did I put the paste on wrong?
I'm so fed up I just ordered a new wraith prism on ebay to see if that will help and if not then I might just order another 3600x or even just plain 3600. This is crap.
Also when I was cleaning the thermal paste off I think I may have had some get inbetween the small gap between the IHS and the top of the cpu. Could some of that thermal paste have gotten onto the IO Die or chiplet and be effecting that? If so is there a way I can remove that without delidding?
