The website is in Germany. Still, I submitted my information.
If you have a touchscreen device (all-in-one or tab) then W8 will be a huge benefit. The layout is very slick and simple.
For traditional desktop or laptop users though, I am not sure what the benefits would be. I'll stick with 7 on my business rig for a while as I haven't had a single issue since I built it over a year ago.
I'm buying it for drive extender aka storage spaces
I don't believe they ever have, but things change with every new version of windows. In Win 7 upgrade versions it just checked if you had some proper files in the /windows folder of your hard drive. Actually it wouldn't even do this before it started installing stuff. IIRC, on a bare drive it'll install either the whole OS or part of it then check to see if you had a previous install, and then won't finish because there wasn't an install already present. Then if you restarted the OS install again it'll detect the version it just installed as a previous installation and finish what it had to and activate fine.
I'm curious if they'll close the double install loop hole from Vista and 7 that allowed you to install an upgrade version on a bare drive. It was a pretty useful trick. You would install Windows on the bare drive but not enter a key during installation, then when it was done installing, you'd just upgrade the clean install, put in the key and everything would activate just fine. I've done it several times and had no issues.
Perhaps but I think many, including me have very little reason to upgrade at this point. If you pick through Mickey Soft's offerings through the years, most of their intermediate products following successful products have not done well.
Win95 - Revolutionary for it's time.
Win98 - Improved 95 but not spectacularly.
Win2000 - Not so good for home users but good product overall.
ME - What?
WinXP - Good product but had some issues.
XP64 - Good product but little to no support.
Vista - Resource hog, buggy, eventually made stable.
Win7 - Stable from get-go.
If you think about it, 95, XP and Win7 are really the only stand out products, with Win7 no where near EOL.
i want windows 8 simply for the drive extender like feature that was removed from whs 2011.
Is this for upgrade from Win7 or any windows? currently running vista.
Aren't you concerned about the features they have removed, like native video playback?
< I was planning on a new TechNet Sub because I have several systems , but
I really like Win-7 , so I will prolly just try this upgrade on one of my extra
XP-boxes to see if I really think Win-8 is the way to go . >
Why upgrade from Win 7 to Crap win 8
vlc is free? And a million times better than wmp
Good man, I was thinking the same thing. That and I don't actually see Win 8 as crap.because eventually they will fix crap win 8 and start to migrate everything over to Win 8. Then you will have to pay twice the price for Win 8.
for this cheap, you buy it and throw in a drawer for 6 months and use it after it's fixed and save money.
wmpc > vlc > wmp
Why not just use real streamlined version of Linux then? Seems a shame just to pay money for a mere storage server.
