I have been using MoodLogic with Winamp 2.8 until now. Yesterday I installed Winamp 3 on top of my old Winamp 2.8, then reinstalled Moodlogic to get it to work with Winamp 3. When I fired up Winamp 3, the Moodlogic splash screen appeared for a second, then Winamp 3 came up with the original skin, right after that the Moodlogic window came up, after which Winamp 3 reappeared with the Moodlogic skin. At this point about 4 dozen error messages popped up and Winamp 3 shut itself down. I have not been able to isolate the source of the problem, but I suspect that there is some conflict between Moodlogic 2.1 and Winamp 3, since Winamp 3 worked without Moodlogic, and Moodlogic 2.1 also works fine with Winamp 2.8. I am not about to give up using Moodlogic, so it's back to Winamp 2.8 for me.
And yes, Winamp 3 did seem kind of slow. Why they had to add video playback capabilities is beyond me... Especially since it wasn't working properly. I tried to play an mpeg-1 file that has a slightly odd resolution, and the video was completely out of sync, plus Winamp only showed the top left corner of the video.
Is anyone else using Moodlogic with Winamp? If so, did you have any success with Winamp 3?
