Bignate603
From my experience the fuel doesn't burn as efficiently as it would be under load so some of the gas can drip down the cylinder walls. But shit I may not know what I'm talking about. After breaking apart two babies vw engines that's what I noticed. I could be wrong. I'm sure someone like ZV would have more experience than I do.
If this is happening it means your rings are already gone, it didn't cause your rings to go bad.
Your rings do a decent job of sealing air at very high pressures, if they can seal a high pressure gas they can seal a liquid (though you shouldn't really have much liquid gas inside a properly functioning cylinder, it should be vaporize pretty well if the fuel injection is functioning correctly).
