Originally posted by: Cha0s
maybe rom, not ram
Originally posted by: Steffenm
Besides, it will never happen until RAM keeps data after losing voltage, and then suddenly it's ROM, like mentioned above, and I don't think that'll ever happen. So: no.
No it's not. ROM is read only. I think you guys are thinking NVRAM, which is non-volatile ram.
Originally posted by: ribbon13
For the low price of $29000 you could get a 90GB SSD from M-Sys with a seek time of 20us and a sustained read/write of 30MB/s. Of course for the same price you could get a RAID0 with 4 of the 23GB ones and that would haul major ass.
http://www.wdlsystems.com/modperl/view_...es.cgi?request=list_aisle&aisle_id=284
Originally posted by: friedrice
The bottom line is, hard drives have certainly reached the end of the rope. There is only so fast those disks can spin, and so small they can get. But, I think hard drives are going to be just one of those things we'll use for a long long time, and 50 years from now, someone will be like, "why the hell are we still using hard drives?"
Originally posted by: statik213
sweet!
Awesome access times, I'd kill to see winxp boot on that....
Originally posted by: L3p3rM355i4h
Why don't we just use RAM drives? I could foresee a system with multiple northbridges, one with the fast (DDR, XDR, whatever) ram, and then a secondary NB that can control oodles of slower RAM, but still much faster than a HDD. Use the 5v standby to keep refreshing your memory. the only problem is, IDK about how much energy that would use.
There's quite the disparity between the access times of the three products. BiTMICRO quotes an access time of 33-48 microseconds, the Rocket Drive has an access time of 0.6 microseconds, and the M-Systems FFD 3.5" UWSCSI has an access time of less than 20 microseconds. But, the M-Systems FFD 2.5" UATA has an access time of less than 0.04 microseconds. What the? Something's wrong here.
How is that possible?Originally posted by: ribbon13
http://m-systems.com/Content/Products/product.asp?PID=34
The UATA's are faster than the U320s
Originally posted by: JohnDoh
Ive thought for a long time there needs to be a movement towards solid state storage becoming mainstream. The hard drive is such a bottleneck in the system, weve moved from 300mhz processors to 3ghz ones and in the same time weve only doubled mainstream drive speeds.
This thing gives me a woody
Capacity
384 GB - 1 TB
Bandwidth
12 GB per second
Latency
Less than 20 microseconds
http://www.superssd.com/products/tera-ramsan/indexb.htm
Originally posted by: Googer
Originally posted by: kcthomas
450MB/s is the speed of USB 2.0 not the flash drive. this is the speed that the data from the drive gets to the computer. the speed of the drive however is not that fast. picture this
1)cpu sends a signal to the flash drive to read data (at 450MB/s)
2)flash drive finds information and retrieves it (much slower)
3)flash drive sends information back to the cpu (450MB/s)
the speed of the operation is only as fast as its slowest part
Not Pointing to anyone in paticular, but know and learn the differance between
MB/s and Mb/s
MB/s is megaBYTES per second
Mb/s or mb/s is megaBITS per second
USB, 1394/Firewire, Ethernet, and neworking interfaces all use megaBITs pers second or Gb/s GigaBITS (not gigaBYTES) per second as their unit of measurement.
http://www.superssd.com/products/ramsan-325/
Would fit right below my EN-8960B00 nicely.
