Will iPhone 6 cases work with the 6s?
CZroe
24,195
857
It protects the bottom from drops without obscuring the speaker or ports.
...so do other cases that also protect it from cosmetic damage as well as impacts to that edge which don't touch the corners. It was deliberate but I still consider it a huge oversight.
Rakehellion
12,181
35
I just use a Skinomi. Thin plastic film doesn't get in the way and protects against breakage and scratches.
CZroe
24,195
857
I've used a few of their skins. They aren't bad! I particularly like the carbon fiber ones. I previously had an ArmorSuit MilitaryShield CF skin for my iPhone 6 Plus. The cut outs on the back were flawless (no metal visible) and it covered the top/sides/bottom pretty well, but it didn't work well with some bumper cases.
My OIS went haywire on that phone and Apple replaced it, so I don't have that skin anymore. Right now I am using a cheap Skintz fake leather skin from eBay that has equally perfect cuts for the camera, mic, flash, and Apple logo, but it doesn't cover the sides at all and works with nearly every case. It looks like it is meant to curve over the edges only as far as the black glass does on the other face, giving it a "metal band" look with equal face and rear materials like the iPhone 4/4S.
I have the edges and screen protected with a Spigen bumper/screen protector (mentioned earlier) and it works great. there is not a single bit of the original aluminum exposed but it feels as thin as if it had no case on at all. There are no gaps around any of the cut-outs. My only gripe is that they didn't give you anything to protect the Apple logo. I know that it wears easily from past experience, so I perfectly aligned packing tape across the back of my phone using the antenna band as a guide before I installed the skin. That didn't work as well as I'd hoped (edges of tape hold air that makes smoothly melted distinct lines when you hit it with the hair dryer), but I did discover that the Apple logo remnants of my ArmorSuit MilitaryShield fit perfectly in the cut-outs from the Skintz skin and looked almost like the original shiny Apple logo coming through. It stayed that way for several months too, but it was sticking to packing tap (no idea how well it would have held to the exposed logo itself).
This works so well that I can't imagine wanting a case that covers the back. A skin does a better job of protecting that cosmetically and does not add thickness. It's very rare that an impact on the back will hurt your phone in the first place and the camera is protected just as well by a bumper, so I can't justify making it thicker with that kind of case. Apple used to sell bumpers back when the glass back could actually be shattered. I wonder why they stopped?
Spineshank
7,728
I like it but it provides no protection for the bottom. That's not OK for such an expensive case.
I bought it because its very low profile. I never had a case for any other iPhone. The aluminum is just too slippery. I have never busted a phone.
blankslate
8,776
556
I use a two part case with a hard polycarbonate shell covering an inner TPU liner that is mil-spec drop tested.
I dropped my phone on concrete with a slim case and it hit just right to do cosmetic damage to an exposed part of the body. Since then I wanted a bit more protection.
The case I have isn't slim but it's not overly bulky either as it fits in my front pocket without issue and it does improve my grip on the phone as well (improved grip on a phone that some cases can give is often overlooked and something I look for when possible).
Ichinisan
28,298
1,235
Incipio NGP, Incipio Frequency, Belkin Grip Candy Sheer :colbert:
The screen would have to land face-down on a rock to do any impact damage. Awesome feel. Slim.
I've used slim TPU cases for:
iPhone 5
iPhone 5s
iPhone 6 Plus
iPhone 6s Plus
Incipio NGP*
iPad mini
Incipio NGP*
iPad mini 2
Incipio NGP (revised)*
iPod touch 5th gen
Incipio Frequency
iPhone 5c
Incipio NGP
* For these 3 cases, I enhanced the tactile feedback of the buttons by using a razor blade to cut a slit along the side of the buttons.
All phones came were still pristine when I sold them. Absolutely 100% flawless.
