Question Wifi crashing in laptop when gaming. Please help!
hentaiweeb
Laptop: asus tuf fx504gm i5 8300h
So recently I've started to observe something really weird with my laptop. Whenever I start playing any game, I only am able to play for like 10 seconds and my WiFi gets disconnected and becomes invisible. As soon as I quit the game wifi gets reconnected.
If it didn't I need to restart PC disable and re enable WiFi.
Tried using my mobile hotspot and is the same issue. I used to use throttlestop to undervolt - 126mv but even that is locked now by a random asus bios update.
I literally am unable to play anything on my Lappy... Please help!
Reactions: JackMDS
hentaiweeb
No self respecting gamer plays via wifi. Ethernet or nothing.
How redacted dumb are you. When someone posts a query try to answer it. If you dont know just go and sleep. Dont start the "REAL GAMER TALK" here even if you have any braincell left alive.
No one needs your justification here about how to be a real gamer. People post their issues to get help. Sometimes it can be serious for them too.
Profanity, even abbreviated, and personal insults are not allowed in any of the tech forums.
AT Mod Usandthem
Mojeer
Lol self respecting gamer, you redacted he is asking for solution for an issue he got not your useless opinion. People like you are the worst in internet, get yourself some brain cells and common sense in your brain
AT Mod Usandthem
hentaiweeb
Not the same problem. But, I have this kind of issue related to my router. My router only works properly when connected to the laptop via ethernet cable. Did you check if your router working fine when connected to the laptop via ethernet cable?
Tried using ether net directly and ether net from the router. Had no disconnections. Issue only rises when using anything WiFi or even mobile hotspot
ch33zw1z
39,838
20,433
What is this downvote point? Who has downvoted this? I haven't done any fault. I just shared what I thought would be useful for the OP. It's unfair. May I know how do you downvote a post?
You're even now 😉
ch33zw1z
39,838
20,433
Try driver updates, checking signal quality, looking for interference devices, etc...
VirtualLarry
56,587
10,227
Just a note, sometimes, when a laptop heats up (and "gaming" laptops are known to do this), sometimes the wifi card heats up and disconnects too. I've had that happen in a cheap business-ish model Lenovo 15.6" laptop with a cheap RealTek N150 wifi card.
Edit: And I will echo that no self-respecting gamer should be playing over wifi.
Reactions: Hans Gruber
JackMDS
29,563
431
On ebay there are WIFI cards for the ASUS TUF FX504 for about $10.
If it was my problem I would get one one and try to replace the current card.
:cool:
P.S. Mr. hentaiweeb I apologize for the bad taste experience that you got here.
Hopefull;y you would stick around, there are Very Good people with ample of knowledge in our forums.
