Uhh, no. Put 1/0 into windows calculator, or any other calculator.Originally posted by: Malak
1/0 = 1, 0*1 = 0
Divide a number by nothing, means the number isn't divided. It is whole. Multiple a number by nothing means there are no groups of that number, thus no number.
Whoever taught you guys math is silly.
Originally posted by: DrPizza
I've actually found a few respected sites that do seem to agree with my opinion, that division by zero is *always* undefined in the real numbers.
However, what I found more interesting was a discussion on 0^0 power... does it = 1, or is it undefined?
Good reasons here: http://db.uwaterloo.ca/~alopez-o/math-faq/mathtext/node14.html
1/0 = 1, 0*1 = 0
Are you trying to be funny? It's not working.Originally posted by: Malak
1/0 = 1, 0*1 = 0
Just because they didn't program the calculator using logic doesn't mean it doesn't work. THINK, stop using those evil machines to think for you!
Originally posted by: JohnCU
L'Hospital is spinning in his grave.
L'Hospital is used for limits
No, really?
x/0 = y. 0y = x. x does not equal y.
Ummm...what you posted made no sense.Originally posted by: Malak
You are still using your silly math rules, not logic. Read what I posted, it makes sense.
No, really?
then why do you mention it?
x/0=x/1
therefore x*0=x*1?
Turn "x/y" into english wording without using any derivative of the word divide or any synonym.Originally posted by: Malak
x/0=x/1
therefore x*0=x*1?
Divide N by x, you get equal parts of N based on x. If x is 0, you have no divisions, thus whole number. You started with the whole number, it can't disappear if you don't subtract can it? The end result tends to be the unit measurement for a single part, but if you don't divide the number, then there is only one whole part isn't there? Thus you still have the whole number.
However, if you take the whole number and say there are 0 parts, as in N * 0, then you are left with 0. If there aren't any parts, then you are left with nothing.
0 parts = nothing. 0 divisions = N
Your math rules also say you can't multiply the same number against itself and get a negative result, but it says you can take the square root of a negative. Does that make sense to you too?
It's a fact: Wikipedia knows everything.
According to the bold part, then "1 division" makes no sense when saying x/1, because you don't truly have one division, you didn't divide anything.Originally posted by: Malak
x/0=x/1
therefore x*0=x*1?
Yes because the square root of a negative real number is not a real number.Your math rules also say you can't multiply the same number against itself and get a negative result, but it says you can take the square root of a negative. Does that make sense to you too?
You're forced to give it to the divisor number of people, that's the nature of math, and why some people love math so much - it's strict. So if it's 1, you're forced to give the whole pie (6 pieces) to that one. Now try 0.Originally posted by: mAdD INDIAN
It should be that a number divided by 0 should equal 0 instead of undefined.
If you take a 6 pieces of pie and want to give it to 1 person, that person will get all six peices. If you want to take 6 pieces of pie and give it to 3 people, each will get 2 peices.
If you have 6 peices of pie and don't have anyone to give it too, no one will get any peices of pie, ie 0.
No, really?
because the world revolves around calculus.
