runawayprisoner
- Apr 2, 2008
- 2,496
- 0
- 76
^ Oh I see how that works. Do you by chance know if the laptop screen goes off when you close the lid? I couldn't tell if it really shuts off or not. The reason I'm asking is beacause I want to save display panel life whenever possible.
With InsomniaX enabled, I don't think it's turned off. You may want to do what TheStu suggested. Command + Shift + Eject to turn off the display.
Also please note that Command + Shift + Eject is not the same as turning the brightness all the way down. If you turn the brightness all the way down, only the backlight is off, but the screen is still on. If you do Command + Shift + Eject, both screen and backlight are off.
