Sounds to me like some setting for your HD is wrong:
1. Defragment!
2. Check if DMA is on!
Edit - also 5 sec for IDE to USB tranzfr is about right. remember USB 1.0 is but slow compaired to your IDE channel.
I first tried installing XP-> SP1-> MB drivers-> all other drivers.
I had the EXACT same problem as you are describing.
Finally it was recommended to me to do the following->
XP-> MB drivers-> all other drivers-> SP1.
Now it works great.
This is a fresh format tho 😱formating is my answer to everything
Originally posted by: Chad
Check for IRQ conflicts.
Also, right click on System and select "Manage" and look in the event viewer and see if XP is reporting any errors.
Originally posted by: Dug
After your fresh install of XP did you notice how fast the very first reboot was?
If that was slow then I would think that there is a hardware problem.
I can't remember exactly but I highly doubt it was this slow or I would have been complaining about this sooner
Originally posted by: bsr
that is some very very low benchmarks, 1MB/s = 8mbps . That is terrible, mine benchmarks around 80Mb/s buffered read , 22mb/s sequential read, 80mb/s buffered write, 21Mb/s sequential write...
is it a 7200rpm drive ? ata100/133 (dma mode 5) ?? Did you improperly format it ?
did you make sure you clicked ntfs and not the ntfs quick format ? I dont really see were it would make a differents, but its possibly the prob.
Originally posted by: CaptnKirk
You don't see this senario happen much any more, but the possibility still exists:
If you have the drives paired on the same IDE header, the speed of BOTH reduces to the speed of the SLOWER component,
that would make the 7200 RPM transfer to match the rate of the 5400 RPM unit, even though the disc speed stays up.
Also the burst rate of 133 drops to meet the ATA100 burst rate. Could you actually have an ATA66 as the slower drive ?
That would be 1/2 the speed of the fastest component on the chanel.
Same thing could be happening if you have the hard drives paired with an optical drive, I do not see where you mentioned what you have.
Next test: Move the 7200 RPM harddrive which you said is the PRIMARY to a MASTER - by itself on IDE 0/1.
Pair the 5400 RPM as a SLAVE, with your Optical drive as the MASTER on IDE 2/3.
This way the faster drive as a single slave will not be restricted by any potentially slower drive mechanism.
While you're doing that check to verify jumper configuration as MASTER or SLAVE, NOT CABLE SELECT.
Run your start-up & time it from Button push to your Icon display. Mine takes 110 Seconds.
Select your Icon & click - time your settings load. Mine takes 45 seconds.
Total time is 155 seconds - thats 2 minutes, 35 seconds, about normal to launch the 20 associated XP programs.
Have you downloaded and tried to run the Maxtor Disc Utilities ?
You'll have to dig for this, as only you know the exact models involved - they can run a Harddrive Diagnostics and analyze for problems.
My suspicion is you have a Drive going South, or an old drive bottlenecking the performance.
P.S. - Maxtor ATA133's don't run as efficiently as the WD ATA100's do.
You may want to consider a change in the future.
Originally posted by: nealh
Here is a suggestion not given....I have an AMD system with SB Live as well try George Breese's pci latency patch..as the VIA chipset and SB live do not live well together..I noted much improved unrar of files
Here is a link...George Breese's website site
BTW..I am using a P4 2.4@3.0 also and I have noted my programs are opening slower than on my AthlonXP system and .nfo and .txt files open very slowing...the only difference beside the obvious is I used WinXP Pro with slipstreamed SP1 on the the P4 and performace was better initially but after installing some programs it has gotten much worse...my point is it maybe the winxp install and a I pretty sure one of my programs has added more bloat....for me I know DVDcopy is an issue if I unistall it I can not click on a link in IE6 and have it open a new window, my PM AT no longer will work...
I need to reinstall winxp now but am too lazy
