Why does most website don't use frame & what do u guys use to write webpage ?
RossMAN
Grand Nagus
Feb 24, 2000
79,084
456
Have you found a webhost yet?
What's your monthly or annual budget for webhosting?
flxnimprtmscl
7,962
Originally posted by: Walleye
i use notepad.
That makes two of us. At least for the whole two I've done
And yes, frames are annoying. There's a reason nobody uses them.
WinkOsmosis
Banned
Sep 18, 2002
13,990
i use notepad.
Frames are fine if you kknow what the hell you're doing, and they make websites much easier to do properly. People seem to like my framed site that I did for a final project in my Information in Cyberspace class... http://www.tortoisehead.com/maryjane
Walleye
Banned
Dec 1, 2002
7,939
i use notepad.
i aggree. i use frames for my webpages, but my webpages are sh1tty, cause im a noob. oh well.
fatbaby
Banned
May 7, 2001
6,427
Originally posted by: jimmyhaha
Walleye nuke geoshity pop-up ?
Walleye World
btw, I don't see large website use frame... probably frame is gay..
english is gay too. i also hate my flaming homosexually gay geforce ti4200 which makes this obnoxiously gay loud hum
jonmullen
2,517
Yah frames have a bad rap and I try to stay away from them, but if done correctly they can be ok. I prefer to use tables in my desing, but even the HTML purist will say thats bad, so I am working towards learning to make my layouts through CSS.
thirtythree
8,680
Tables are bad?!?
flxnimprtmscl
7,962
Tables are bad?!?
Exactly... If you're not using tables or css how are you supposed to arange things?
Zugzwang152
12,134
I'd wait till CSS develops a little more first...I found it a little annoying that some things werent supported....
igowerf
7,697
Tables are bad?!?
<p> tags and css can do some amazing things.
WinkOsmosis
Banned
Sep 18, 2002
13,990
I use Dreamweaver, and edit some of the code by hand (in Dreamweaver). Screw that notepad crap... unless you're an ubernerd, there's no reason for that.
Staples
4,953
119
I use Ultra Edit, the same editor I use for C/C++/Perl (it sucks in Windows)/PHP/Java and of course HTML.
lukatmyshu
483
If you look at ANY API reference it's done with frames. Frames can be a logical way to organize your site, as well as allowing you to maintain persistent information across a users visit. It depends on what you're trying to do ... if you want to make a nice site you need DreamWeaver, Photoshop and every single browser imaginable to see how it reacts. I used to be pretty good with HTML but now that I haven't used it in 4 years I honestly suck at it. Can't use style sheets either ... one of these days I'm really going to have to learn it again. Sucks 'cuz it's already on my resume.
BurnItDwn
26,366
1,879
Lots of places dont really need frames ... they are OK if used correctly. (not in excess)
I use vi as my editor, and postgres SQL for the DB
Chaotic42
35,249
2,386
Frames are evil. I just use tables.
I use jed, an editor for linux (at least) to make webpages.
