IHateMyJob2004
Originally posted by: Accipiter22
just curious as to why diesel engines exist...
Actually, looking back at history, the question should be ... why do gasoline engines exist?
Yes, but the diesel needs much higher compression ratios (i.e. much higher temperature and pressure) to cause the fuel to self-ignite. If you put 87 octane fuel into a car with 12:1 compression, the mixture will self-ignite before the spark plug fires. If you put diesel in that same engine, it won't get hot enough even with the spark plug to sustain combustion.Originally posted by: Fenixgoon
compression ratio has to do with temp/pressure, no? at least i got the spark plug part right 😀Originally posted by: Zenmervolt
You are mistaken. Diesels have compression ratios well above 16:1. The highest I've seen in a gasoline engine is around 12:1. It's the very high compression ratio that allows the diesel to ignite without a spark plug. If you put diesel oil in a gasoline engine, it may not even ignite at all, even with the spark plugs firing.
ZV
<--- not a car buff
For all the reasons I stated earlier... It is only within the last 10 to 15 years that diesel has become a viable alternative to gasoline in everyday applications. Prior to the 1990's, diesel was simply not suited to anything other than special applications that could overlook the myriad serious drawbacks that diesel used to carry.Originally posted by: IHateMyJob2004
Actually, looking back at history, the question should be ... why do gasoline engines exist?Originally posted by: Accipiter22
Originally posted by: Iron Woode
Not here it isn't.Originally posted by: Baked
Diesel = Cheap
Gas = Expensive
It's that simple.
Gas $.85/litre
Diesel $.97/litre.
Because until VERY recently, diesel was incredibly inconvenient. Until the 1990's diesels required glow-plugs and at best a 30 second wait before you could start the engine (some engines required much longer), diesel congeals at low temperatures (I remember as a kid in 1996 or so in Ohio we had a cold snap in the middle of winter and school was canceled for two days because all the diesel in the busses congealed and none would start), diesel engines used to be almost impossible to start at low temps (some semis had small gasoline engines to start their diesel engines during winter), diesels used to emit vast amounts of particulate emissions that caused severe asthma problems (similar to heavy coal emissions), and the NOx emissions from diesels used to be abominable.Originally posted by: vi_edit
The real question is, why does gasoline exist?
Diesel engines are more efficient and typically last much longer than a gasoline equivalent.
It has only been in the past 10-15 years that diesel has become a viable everyday alternative to gasoline and the engines still cost more to produce.
ZV
Originally posted by: C6FT7
If anything should be taxed more heavily it's tobacco products, namely cigarettes. People will still buy them even if they were $15/pack. :roll:
I understand all that. My post was to point out that diesel wasn't viable for everyday automotive use until recently because it required additional attention. I fully understand that diesel was and is worth those downsides for hauling and other special applications.Originally posted by: cavemanmoron
ZV
That happens because the fuel companies wait too long to deiliver "Winter Mix"
diesel fuel.
When mixed properly Winter mix is good to -25f.
Very often,the first cold spell happens when the trucks still have straight #2 fuel oil/
diesel,which gels at about 25+f.
If you know a cold spell is coming then you can add Anti-gel additive,and some #1 diesel
or Kerosene to the fuel tanks.
This happens at my work sometimes,we get a around zero cold snap,and the trucks/loaders etc start to gel up.
I have been bitching for 20 years that starting October 1st our fuel should be
70/30% which is good to about -10f or so.And any fuel after Dec 15th should be 60/40%
I get told whenever I mention it,that this costs a little more money. :|
A Diesel Truck engine makes more torque than any gasoline engine,
and torque is what is needed to move a heavy vehicle.
Originally posted by: CorCentral
Elly---- Dirty burning fuels should be taxed more...... Plain and simple.
K1052---- Sudden? Who said anything about sudden? They're already paying more at the pump! Make cleaner burning engines!
Originally posted by: glenn1
can't trucks just use normal gas?
Why can't an F-15 fill up on 89 octane unleaded rather than JP4?
Originally posted by: mjrpes3
I wonder why type of MPG you'd get if you combined these three factors
1. Diesal
2. Hybrid
3. Small form factor
Originally posted by: laurenlex
More efficient, more durable, more powerful. That is all.
Originally posted by: tfinch2
The ownage is strong in this thread.
Originally posted by: DurocShark
TPAD
You do realize that the diesel of today isn't the same as the dirty diesel of yesterday, and the diesel of tomorrow is even cleaner?
I think it's funny that diesel is more expensive than gasoline in the first world, considering it's cheaper to produce. In the third world it's always cheaper.
Originally posted by: Vic
Horsepower is a marketing tool for gasoline engine makers. Torque is where it's at and diesels make torque in boatloads.
QFT
The more Torque at low rpm is better then high ammounts of HP anyday.
Originally posted by: YoshiSato
Originally posted by: lobadobadingdong
Oil companies have invested billions in gasoline refinerys/distrobution, and are not about to let them go to waste (anyone else notice thier quarterly profits lately?)
They made like 10 billion(10,000,000,000) dollars in the past 4 months at a 89% profit.
