Originally posted by: 13Gigatons
1. Cars have a natural FS where the whole car will "hum" making the output greater. Rappers and boomers exploit this, people who want sound quality will try and use an eq to produce a more flat response.
2. Car gain can be 12 db per octave below say 100 hertz and all the way down to 10 hertz. Great if you listen to pink floyd and want really loud 10 hertz bass.
Originally posted by: PurdueRy
I don't know what you mean by it takes 37 feet for a bass wave to mature...
Sound waves are measured from peak to peak (or trough to trough) to find the cycles per seconds. This is what is known as the frequency (what you might refer to as 30hz). Sound waves can also be measured for their size or height. This is what is known as the amplitude (or loudness, size of pressure differences). The average sub bass note takes 37 feet to mature simply means that when you measure the sound wave of those low frequency subs the distance between peak to peak (or trough to trough) is roughly < drumroll > 37 feet! So, the average car stereo listener (assuming they are listening IN the car) will never hear the mature sub note. They hear one that has not completed it's movement.
I can agree with most of your statements in that a "sub" woofer takes on frequencies that a normal woofer will have a hard time reproducing. In my defense, I did edit to include the masses use of band-pass subwoofers - a cheap, loud (boomy), and easy way to get that desired sound that is so popular in the rap culture. I'd forgotten about that as I was always into quality, not quantity.
Sorry, never said that a microphone couldn't pick it up. That's just like saying that the occupants of said car cannot hear it. They both can. It's a fact that the occupants (and the microphone) won't hear the wave as it was intended. That sub note will be at it's peak at ~37 feet. There's no way anyone (or thing) in the car can pick that up. That is why if you point your sub rearward (instead of forward) you can gain 3db. Simple trick, but it gives the sub note a couple feet more to mature. It's really just the limitations of car stereo. There's lots more, but were really just talking about subwoofers.
What's the difference between the note that's heard and the note that would be heard in an outdoor field?Originally posted by: bigboxes
Originally posted by: Excelsior
Car subs are optomized for output in the mid-bass region (over 30hz) and this is the cause of boomy bass. It is often thought that true deep bass causes this, but that is not true.
Sorry, but I think it's the sub-bass (below 25hz) that is the boom you speak of. The reason it's called sub is for sub-hearing (20hz). You feel more than hear. It's that ultra-low bass that travels much farther than normal audio waves. A (sub) bass wave takes 37 feet to mature explaining why it sounds so much louder in your living room than to the idiot sitting at the traffic light. I used to have a sub in my trunk and had a sub-sonic filter on the sub. This cut out all frequencies below 25hz. The sub was much tighter, less boomy, the tweaters and mids sounded much more natural, and the amps (and charging system) were much less stressed. You rarely heard the sub-bass outside the car, but you stuck your head thru the window and "wow".
Edit: my bad... I forgot about the ghetto band-pass boxes. They sound boomy and are cheap to purchase and power. A favorite of the rap generation.
Originally posted by: mattburk
Most car subs are garbage. Many of them are one note wonders and do not accurately reproduce a large frequency range. Instead of producing a signal with a linear spl from lets say22hz-85hz like a good home theatre sub, they will produce a solid output in lets say the 40-70hz range but not much above that or below that, that is why they seem boomy. A solid enclosure is also important; many car subs do not have an enclosure as they are using the car as the enclosure. If possible it is better to have a solid enclosure built for your sub.
And you are wrong.![]()
A good sub will not sound boomy at any frequency, whether it be 15Hz or 40Hz.
He said a good sub, not a good driver.Originally posted by: rstrohkirch
Alignment determines response
A "good" driver could easily have a exaggerated response
I know. But he may not have been.Originally posted by: rstrohkirch
I am refering to a loudspeaker driver
Originally posted by: spikespiegal
A couple years ago I helped a friend build an 'audiophile' class subwoofer for his home theater system because we didn't like any of the commercial options. The big, commercial subs we heard we're simply too expensive, and didn't have any real impact unless they distorted. We were convinced we could build a better unit from scratch.
We designed the thing around a 15" Adire driver, which is oddly used in both high-end home theater applications and car pro audio. When we finally got the thing built to specs we had a cylindrical enclosure about the size of a 55gallon oil drum tuned to about 16hz free air resonance. We added a generic 700 watt plate amp even though we knew it was over-kill.
Sound quality is amazing. Not only is the beast entirely free of distortion at wall splitting levels and sounds awesome for even classical music, the depth of bass would make a T-Rex run in terror.
I live in 'ghetto-ville' USA, and am treated daily to the best boom trucks and 'boom-chucka-jungle-jumpin-music' money can buy. Trust me, that Adire rig is an order of magnitude lower in bass frequency, can go louder, and far cleaner. I wrote a custom .WAV file that does a low frequency sweep from 0-20hz, and there is no boom truck I've ever heard that can compare to what the Adire does while that WAV file is playing. A boom truck will rattle your windows and door hinges, and otherwise be annoying. The Adire sub while playing the frequency sweep will shake various walls in the house violently as it hits resonance points while your sinus's feel like they are going to explode - and you can't hear a damn thing. We've already stress fractured his front wall, and we never turn the amp up beyond 25%. I'd love to put that Adire rig in my trunk and pull up next to some boom trucks at a stop light and treat them to some *real* bass.
