Using 2 hands with power steering for most people means a gross overcorrection and a wreck. Also, its harder to initiate a turn to lock situation with 2 hands then 1, as with one you can instantly slide into a open palm and spin the wheel around whereas with 2 hands you need to remove 1 hand, or you can go about 90 degrtees MAX before your arms are crossed and you cant turn it anymore.
I don't buy that at all. To be able to keep turning the wheel with one hand you can't actually grip the wheel all the way around, you have to switch to pressure only (open palm)... which is how most people turn when using one hand. I'd love to see you pull that stunt if you ever had to swerve off-road. The wheel would be jerked out of your hand so fast on rough terrain you would be out of control in seconds. I bet everyone here claiming to be able to drive better with one hand has or will grip the will tightly with both hands when an actual emergency arises. You have better control when having to "fight" the steering wheel (i.e. rough terrain) when using two hands. Period. There really is no debate which is safer.
