Originally posted by: The_good_guy
from a guy who has driven quite a bit.. in rather tight situations.. let me tell you nothing is better than 3/9. When you want fast reflexes.. and solid control of a turn, the positions of 3/9 are the best.
12 o clock is for gangsta.... it is for the loser who believes in Bling. If you seriously think you can outhandle me with one hand.. your nuts..
When it comes to handle an understeer even an over steer if you happen to do that on a FWD car, then you wont have enough control with one hand on teh wheel. The only time one hand on the wheel works, is if your going in a straight line..
Even so I dont put it at 12, I put it at 3/9.. However the forces required to make a turn with one hand is a lot more with one hand. If I put it at 12 it would be a bit lesser, but it still isnt an acurate turn nor is it a turn with ease..
I suggest you drive with 2 hands.. cause your going to crash one day with your hand on the top of the wheel.. and if you got an airbag car, careful, it can deploy and break your hand if its in the 12oclock position.
