Originally posted by: notfred
I'd recommend finding a better physics teacher. Unless the book is using similar forces acting on its contact with the desk as a tire on the road there is NO difference in a coefficient of friction whether a book is on its end, on its tip, or flat on its back. In reality? Perhaps there is a difference, but from a simple physics equation point of view there is no difference.
Come on Skoorb, you really think I'm going to believe you over a physics professor? We are not talking about a "simple physics equation", we're talking about a tire, which exists in reality. Yes, there is a difference in the coefficients of friction for the different sized tires. You say "but from a simple physics equation point of view there is no difference". What is this "simple physics equation you're talking about? One that already assumes you know the coefficient of friction? Of course it doesn't matter in that equation, as it's already given.
I made no error - it takes the exact same amount of force regardless of its orientation on the ground. I will qualify that again by mentioning that there could be unidentified factors working with the brick and its surface similar to how they will with a tire on ashphalt, but from a basic mathmatical view there is no difference, and if you answered on a physics exam that there was a difference (without being given the additional factors at work, which are difficult to identify) you'd get the answer wrong.
What is this "basic mathematical view" you're talking about? You keep referring to equations, but I've yet to see your "simple equation" that computes the coefficient of friction of different sized tires. All your equation assume that the coefficient is given to you. In such a case, you should be given different coefficients for the wide and narrow tire.
Given two "pure" materials - the kind one would only find IN a physics question the flat brick vs.the brick on its end are exactly the same in regards to the forces needed to push them because their coefficient of friction is the same.
No they're not, give me any shred of evidence showing that the coefficient of friction is the same for all objects made of the same material.
