Jeff7
- Jan 4, 2001
- 41,596
- 20
- 81
Dammit, I think I'm going to spend way too much time there....
For those interested, somebody made a complete starship database.
http://www.ex-astris-scientia.org/starship_database.htm
Klingons/Romulans
i can *maybe* buy that they cant fire phasers when cloaked because the cloak takes up a huge amount of power.
but why cant they fire topedos?
Actually it's a matter-antimatter warhead. I have no idea why it's called a "photon" torpedo.So Photon Torpedos are made out of Photons?
Actually it's a matter-antimatter warhead. I have no idea why it's called a "photon" torpedo.![]()
Photon-based forcefields are used to keep the matter and antimatter separated.Actually it's a matter-antimatter warhead. I have no idea why it's called a "photon" torpedo.![]()
You people call yourself nerds? I'm ashamed...
Undiscovered Country: Klingon Bird of Prey could fire when cloaked quite effectively. Kirk couldn't do anything until they reconfigured a torpedo to home in on the exhaust of a ship.
Star Trek TNG: Some episode where they find an experimental, mutinous Federation ship that rematerialized inside an astroid. It could cloak, and pass through matter, so I'm assuming that thing could fire. In that episode, they said something about setting up a treaty between the Romulans and Federation to prevent further research on such cloaking technology in the past; this ship violated tha treaty.
Nemesis: No one watched this, huh? The Scimitar, huge Romulan (?) slave people ship. Could fire when cloaked, but the Enterprise and other Romulan ships used sweeping phaser fire (spray and pray) to pin point the location of the ship.
They always point out that cloaked ships shouldn't be able to.
Two plot devices:
"Can't fire when cloaked."
"OMG! A ship that can fire while cloaked!"
The eagles you mean?Why didn't the birds just fly them into Mordor in the first place?
To be or not to be...
Isn't it funny that firing while cloaked is experimental in kirks and picards time? You would think science would go faster in the future!
Its kind of live leveling up in a game. Each successive step requires more and more points.Isn't it funny that firing while cloaked is experimental in kirks and picards time? You would think science would go faster in the future!
Ships can fire when cloaked. They just choose not to.
In early cloaked ships it was impossible to fire at all when cloaked, as the build up and discharge of energy by phasers, disrupters, etc would explode the cloaking generator because they couldn't handle the rapid change to the ships energy level.
Later models of cloaked ships could fire, as they improved the cloaks buffers and the ships power regulation.
The reason ships don't fire when cloaked is that they can't fire with any effect when cloaked. Photon and quantum torpedo's are not guided, they are aimed and travel at great speed.
When a torpedo passes thru the cloak it is deflected a small amount, a random amount. At the distances its safe to fire torpedoes at they wouldn't hit anything. Cloaked ships also can't get closed enough to a target to ensure a hit without being destroyed by blast. Phasers and disrupters are also deflected, making a hit unlikely.
In the Undiscovered Country the Klingons used a prototype to fire when cloaked.
However, when you see the torpedo leaving the ship you see the ship is momentariy visible. That's because the prototype was specifically designed only for firing when cloaked. Things like life support could be turned off or powered way down and were only powered by batteries. By limiting most systems on the ship, and designing them for the lowest possible power output, it was possible to re-establish the cloak very quickly after a torpedo was fired The ship was worthless in a space battle, it could only lay in wait for the enemy to come into range. They could, in fact, only travel at a very low impulse, and warp factor even when the cloak was disengaged.
Fortunately, the Federation took measures to counter act this kind of ship in the future. And educated its officers and men not to say a cloaked ship can't fire, but can't effectively fire.
OMG ... you bastard! You spoiled it all because you are thinking too much.Why can't you just cloak the torpedos
And, wtf, what is wrong with a particle beam or torpedo emerging from nothing? And keep moving?
This is all about game-like restrictions and nothing practical ... as if there is something practical to the whole thread.
In 2293, Spock and McCoy modified a photon torpedo to follow the trail of ionized gas from Chang's Bird-of-Prey at Uhura's suggestion. This exposed the cloaked Bird-of-Prey and allowed its destruction by the USS Enterprise-A and the USS Excelsior. (Star Trek VI: The Undiscovered Country)
I always thought that photon torpedos had some form of guidance...
