exar333
- Feb 7, 2004
- 8,518
- 8
- 91
Well the CPUs were like within $10-20 of each other retail. And you do certainly have to buy the more expensive supporting parts...but you're still getting what you pay for. x99 is much more capable than z97 and your ddr4 will last a lot longer.
The main point I'm trying to make is that right now it's like you have a choice between current generation and next generation, and now more than ever you're getting your money's worth by stepping up to HEDT. Neither is going to change all that much over the next few years. Both platforms aren't going to get anything but minor bumps for a long time.
Look at the broader choices you have to make. If you buy more ddr3 now, that's just more ddr3 you're going to have to toss away when ddr4 becomes standard. PCI-E SSDs will become common soon too, and almost none of the mainstream boards have an x4 m.2 slot. Even if you use standard slots you can't put in more than one drive without running out of lanes and starving your GPU.
It just seems to me that the mainstream platforms are going to feel crusty and old a lot sooner than they have for the past few years. And 2-3 years from now you're not going to get much more than you are with Haswell-E right now. It used to be the case that HEDT got you more memory channels and lanes, neither of which you really needed. The value wasn't there, it was all theoretically better but made zero difference. That's not the case with x99.
This.
And I would argue that a 'ROG 1155' <> 'ROG 2011-3' MB. Grab pretty much any x99 MB for ~$350 and you are pretty-much on-par with the best 1155 board. You are comparing apples to oranges; mainstream to enthusiast. I know people bust-out the car analogies, but it's like comparing a base-trim Ford to a base-trim Audi. Different beasts...
