Who really knows what gives V8s their throaty exhaust note?
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Originally posted by: CFster
CART engines are 2.65 liter turbo V8's that rev to 12K. They make around 750hp. (They used to rev to almost 17K)
IRL engines are 3.5 liter naturally aspirated V8's that rev to 10.5K. They make around 675hp.
F1 engines are 3.5 liter naturally aspirated V10's that rev to 19K. They make around 900hp.
All sound very different and unlike anything else in the world.
Well, the main reason that CART and IRL V8 engines sound different is the turbocharger's muffling effect on the CART cars' exaust.
ZV
Well I assume no one is going to answer my question, so, here's the answer ..........
I'm not going to tell you, HA-HA ;)
The noise is from the exhaust gasses breaking the speed of sound, what you are in fact hearing are mini sonic booms.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Now that's just plain cool. :)
ZV
geno
25,074
4
Originally posted by: MercenaryForHire
*insert sound of Ferrari 360 hitting 7K here*
*drools*
- M4H
that's a flat-plane crank V8, the sound shares little with that of cross-plane crank of American V8's
Ornery
17
*drools*
- M4H
3.6-Liter, 90-Degree V8, 40-Valve, Twin DOHC
It's the displacement that makes the American V8s more 'throaty', not the cross-plane VS flat-plane configuration. I'd MUCH rather have low end grunt of a large displacement, than the buzzy, hyper power of a little screamer. There's no exhaust tip in the world that will compensate!
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
*drools*
- M4H
I'm sorry, but Yahoo is not exactly reliable. A 1,000 CID V twin will still sound like an 80 CID V twin as long as the crank has the same angle. The larger engine will just have a lower-pitched sound. The rhythm is the same. You can argue that it's displacement until you're blue in the face but the fact of the matter is that crankshaft design and to a slightly smaller extent exaust acoustics play by far the largest roles in determining the sound of an engine.
ZV
Ornery
17
"You can argue that it's displacement until you're blue in the face but the fact of the matter is that crankshaft design and to a slightly smaller extent exaust acoustics play by far the largest roles in determining the sound of an engine."
Topic title is "what gives V8s their throaty exhaust note?"
Tiny V8s aren't 'throaty'. The answer to his question is the size of the cylinders, first and foremost.
Demon-Xanth
20,551
Roger:
I believe it has to do with the pulses hitting the barrier between the hot exhaust air and the reletively cold ambint air.
And about Ferraris, a 348 Testarossa only did 14.8 in the 1/4. Tons of cars will waste it. Back in the '80s when everything became suck, sports cars were not spared. (one year, the Corvette's engine options ranged from a 165HP base to 210HP top option)
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Again, exaust design can do a lot. Porsche's 2.5 litre inline four is a good example of this. Listen to the idle of a 924S or a 944 with the stock exaust system and it will sound deeper and more mellow than just about any other 4-cylinder car.
ZV
geno
25,074
4
It's a combination of the two. Flat plane cranks make more of a poppy/buzzy noise, as do small displacement per cyl motors. However, the cross plane crank gives more of a "lumpiness" to the sound of the motor. Think about BMW's 4L V8 and compare it to a cross plane V8 like Ferrari's (granted, different displacents) they have completely distinct sounds. I know, different heads, different boreXstroke, but IMO, you can't deny that crank layout plays a big part in the sound of the motor. The Ferrari sounds like a motorcycle while the BMW has a smoother traditional V8 hum to it
Ornery
17
The point is, our rice boyz are trying to get that sound via exhaust tips, which is NEVER going to happen. Some of them go as far as putting headers and exotic exhaust systems on. It still ain't gonna happen! You can't make a weedwacker sound like a Harley!
geno
25,074
4
True, you can only do so much to change the tone of a motor - and as they've proven, it's very easy to ruin it ;) BUT - don't forget about the legions of V6 Blazers/Explorers out there that try to duplicate the sound of a V8 with 5" tips. If anything, I noticed that junk a long time before ricing was a fad. Any truck that comes with a V6, but is available with a V8, you can count on finding people welding massive tips that look like bazookas on the back of their beat up 89 Blazer :p
NuKe9
1,524
Originally posted by: WinkOsmosis
Originally posted by: TechnoKid I believe one of either the IRL, or CART, or F1 engines is small displacement V8, but can rev to like 13,000 rpm. This is because the stroke of the engine is much shorter.
Those little nitro engines for RC cars rev to like 25,000 rpm :Q.
There are some that turn over 40,000 RPM!! Put out close to 2HP as well, not bad for a 2.1CC engine.
Example
Roger:
Incorrect sir, the exhaust gasses are leaving the combustion chamber faster than the speed of sound.
If you could dump the exhaust directly into a chamber with the contents (air) heated to 1,200 F, it would still make the same sound.
ElFenix
102,407
8,595
Originally posted by: Zenmervolt Again, exaust design can do a lot. Porsche's 2.5 litre inline four is a good example of this. Listen to the idle of a 924S or a 944 with the stock exaust system and it will sound deeper and more mellow than just about any other 4-cylinder car.
ZV
and with cylinder chambers the size of a 302 i would expect it to sound deeper.
bob4432
11,727
46
No,no,no !
Why would it burn the exhaust valves?
If you run a engine with open exhaust ports, the exhaust valves will burn, not because of the scavenging effect, but because when you shut the engine down, cold air will enter through the open exhaust port, thus warping the extremly hot exhaust valve.
In fact, removing the exhaust manifolds and pipes, you drastically reduce the scavenging effect and lose horsepower and torque.
Gasoline does not explode inside internal combustion engines, it burns rapidly.
A flame front starts at the spark kernal between the spark plugs eletrodes, this flame front propigates across the combustion chamber, preignition (Ping, detonation) is gasoline exploding inside the cylinder(s), this causes a high pressure wave to travel very rapidly, this wave makes the engine block ring like a bell, thus you hear it as "ping".
Ok smart guys, here's a good question for you, let's see how everyone's memory is (I asked and answered this question before), what makes the exhaust gasses so loud ?
here is your answer!! this is it, the headers / manifolds keep the exhause valves "insulated" and them cool slowly. there are reason why atleast all the engines i have seen have some type of header / manifold. even the ones making 5000+HP
bob4432
11,727
46
Originally posted by: Nebor
Originally posted by: OS
Originally posted by: Iron Woode
Inserts sound of 1968 Hemi Dart pulling a 10 sec 1/4 mile ET.
**Boy Yeah**
Take that ferrari!
[FnF]
You owe me a 10 sec car
[/FnF]
[FnF]
what's the retail on one of those?
more than you can afford buddy, ferrari "vroom, vroom"
[vin diesel]
smoke him
[/vin diesel]
[/FnF]
The funny thing is, people think that's realistic... Sure, some ricer might beat a Ferrari off the line.... but get up over 100mph, and Ferrari precision reigns.
older american muscle cars went straight well, but you have to setup a car quite a bit different for "real" handling and traction the way a autocross car travels.
bob4432
11,727
46
ZV
engine design. the design that porsche uses is not the same as toyota
bob4432
11,727
46
many factors determine what a engine will sound like. cam, crank, valvetrain, compression, turbo/blower, heads, it all adds up in the end. i don't think there is any 1 item that does it, but the combination of all. i have heard some small (377 sbc) sbcs with very trick heads, a huge roller cam, 14:1 compression etc that sounded like a big block. this motor made well over 600HP though, but it wasn't a buzz saw
sillymofo
Banned
Aug 11, 2003
5,817
Originally posted by: TrueBlueLS
I've been thinking about this for a little bit now. Could it maybe be the length of the tips coming off the muffler that resonate?
GLASSPACKED
bob4432
11,727
46
GLASSPACKED
glasspacks suck
