who is wrenching today?
Page 15 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Imported
14,679
23
I kept the height the same as it was previously (measuring from pinch welds) and didn't touch any of the alignment bolts when doing the install. Unless alignment changes when removing the upper-arm bolt or the shock-body being not as tall as what was on their previously?
A set of Motons was out of my budget.. I believe Moton was acquired by AST recently though.
hanoverphist
9,928
23
im putting the ac idler pulley into my civic today, hopefully the compressor works and ill have ac in it this week. im also going to fluch the cooling system in preparation of replacing the rad and thermostat this weekend. if i have time im going to pull my rt fender and start pounding out the dented corner in prep to painting next month. i love project cars!
mvbighead
3,793
Replaced a power window regulator in 00 Jeep GC yesterday (rear passenger door). For $65, it sure beats what most people pay a mechanic/dealer. Didn't take too long, for even a novice like myself.
herm0016
8,401
1,028
i am installing firestone air-bags on my 09 gmc 1/2 ton. one side is done but the jounce bumper on the pass. side will not come off. the dealer could not get it off either. bah.
going to take a hack saw to the rubber and get my 1/2 inch socket on it.
exdeath
13,679
10
Camry left me stranded for the first time in 15 years. $40 ignition coil that took me 10 mins to replace (requires removing distributor) in the field. But the morning was lost on waiting on a ride to my house for tools/clothes change, standing in line for half an hour at the parts store waiting for people who don't know what they need, etc.
Don't carry tools in my cars, they do no good since any failure I will have will involve replacing a random part which I won't have on the spot anyway.
I just replaced the coil almost two years ago, and at that time out was still the original 14 year old OEM Denso 1995 coil. Not sure if it's because the cheap chinese Autozone shit (only part they have when you need to get it moving right now) or maybe the ignition module is getting flaky and not closing the circuit completely causing too much back EMF and heating up the coil, etc. The resin filler was cracked open and the secondary measured 3 ohms when it should be like 300k or something.
CraigRT
31,440
I need to buy an old car again so I can fix things and work on the car... My new car is just no fun that way.
Pinepig
196
7
Picked up a new project about a week ago, have it running now just for ease of moving it around, 1974 2002 autotrajic ( better for the 5 speed swap as they have a wider tunnel right where you need it for the clutch slave ). Surprisingly clean accident free for 700$.
Got it stripped down today so I can start filling holes for stuff that has to go like lower trim line, entire front bumper, stupid DOT side marker lights. Picked up some sheet metal yesterday, tomorrow I'll start cutting out patches and welding them in.
This one will get a complete color change to light blue, refurbed suspention ( new bushings, bilstiens, springs, anti roll bars ) and a M42 1.8 16v and the 5 speed out of a late E30 318is ( so just a mild good driving car ), not stupid like my 75 2002.
thedarkwolf
9,000
110
Sweet 2002.
Put new belts on the old 89 dodge caravan turbo. Was planning to replace the whole van but the cheap used car market is crap atm.
Pinepig
196
7
The 72 tii I just finished for a friend of mine ( I hate working on other peoples cars, this was an exception ).
This is him driving it off.
Project for after the 74, 71 Bavaria, this car will be stupid, Boosted M30b35, to the tune of 5-600 hp. :)
My 75 when I was putting the motor back in after cleaning up the engine bay.
that bay,
alkemyst
83,967
19
that bay,
how did you do that just today?
skyking
22,047
4,831
bringing this back for an update: The new injectors arrived, I just got them in and fired it up. Smooth as a 6 cylinder diesel can be :D
jlee
48,512
220
I replaced the igniter in the MR2 today, chasing an intermittent stumble - it's doing it much less often, but it's still there..
manimal
13,560
8
Did a PPI for a friend on a 1980 928S euro model. Told him to run away from it....
Rainy day for construction so we pulled a trans on our f250 and sent it out to be rebuilt.
skyking
22,047
4,831
Made some test runs and tuned the pump a bit. Tomorrow I'll install the new turbo.
thomsbrain
18,148
Carbotech XP10/XP8 racing pads and Centric rotors, plus a fluid bleed (ATE Blue) for the S2000.
Fuck. Rotor. Screws.
Sep 7, 2009
12,960
I tightened all of the cross braces on my z4 and installed the bmw strut brace I've had for awhile. Also cleaned up the engine bay and wiped down all of the rubber seals, along with a pre-season detail.
The ranger got an air filter and oil change, along with replacing my coolant overflow tank hose which had sprung a small leak. It also got a minor engine bay wipedown, mainly to look for anything loose, cracked, or aging.
Next up is transmission and diff fluid change on the z4.
....My ranger doesn't specify diff fluid change interval. It's on the original fluid at ~150k, but it's an open differential. Is it worth changing?
Howard
47,989
10
I took them out of mine and never put them back. The centering rings do a good enough job holding them in position anyway.
jlee
48,512
220
I did an on-the-road fix on the Forester today - had cruise set on the highway when the car stuttered and threw a CEL. I checked it with my Accessport and it was a wastegate-related code. Turns out a vacuum line (associated with the wastegate) had split. I reset the codes and fixed the vac line - problem solved.
I need to change plugs and fuel filter on it too - maybe next weekend.
skyking
22,047
4,831
ran it across a mustang dyno ,but the software was glitched and would not print a graph. I snapped a crappy cellphone picture.:thumbsdown:
He'll run it again for free after I get done porting it.
manimal
13,560
8
Picked up a used Bosch mounter and balancer and used it for the first time. Sadly the balance was completely screwed up because like an idiot I forgot to use the hammer drill and mount them to the floor of the shop..
Three hours later were all good!!!
halik
25,696
More info! Scored cylinder walls?
JCH13
4,981
66
MS3 had been running like crap occasionally, threw a CEL for a lean burn condition. I popped the hood and tada! A coupler on the CAI had come loose. Tightened it up and was on my merry way.
