DrMrLordX
I got lucky, I was just able to pick one up. A Sapphire Nitro.
At what price?
$1199 + tax. Local shop.
Wow. 5950X is a BOTTLENECK???View attachment 73819
Seems to actually help a lot. When I ran the bench on the 3090, my average FPS was about 180, and the bottleneck was the GPU 99%. Also my lows are much higher with the new card.
Would be interesting if the 7950X3D reduces the CPU bottleneck to less than 50%.From what I have heard, 4090s and the good 7900 XTX cards are so fast that even a 13900k can be a bottleneck.
Radeon driver control panel provides ample options for overclocking. Just be careful! I think it doesn't provide any safety protections (from my experience with RX 580). You could burn your card out if you set some option too high.Does anyone have experience or a good guide for OCing these cards?
Thanks, I will have to check these out. I just ran timespy, and got an excellent score, without any tuning to the GPU. Strange though, it took me a while how to figure out how to get a valid score. 3dmark is picky about any driver tessellation option changes.This looks good with plenty of details: https://hwbusters.com/gpu/amd-radeon-rx-7900-xt-power-analysis-overclocking-guide/
This has an intro: https://www.thefpsreview.com/2022/12/22/overclocking-amd-radeon-rx-7900-xtx/
Guru3D's OC attempt: https://www.guru3d.com/articles-pages/amd-radeon-rx-7900-xtx-review,30.html
TPU got pretty decent OC out of the reference card: https://www.techpowerup.com/review/amd-radeon-rx-7900-xtx/39.html
I think alpha coolJust got a reference model for slightly over retail from a kid on FB
Stock vs. OC
Result
www.3dmark.com
OC vs. my previous 3090
Result
www.3dmark.com
Pretty satisfied so far. Had some bad crashing on the Witcher 3, which seem common according to the internet, but weirdly it stopped happening when I ran the game on my TV instead of my monitor.
Is anyone aside from EK making blocks for the reference cards? EK's prices are nuts
I scored 26 439 in Time Spy
AMD Ryzen 9 5950X, AMD Radeon RX 7900 XTX x 1, 32768 MB, 64-bit Windows 10}www.3dmark.com
Wasn’t I called crazy yesterday for saying 7900XTX is that fast? IronicYou're closer to the 4090 score than the 7900 XTX (reference) score that Guru3D got in their benches 🙂
A lot of people with driver problems on AMD reported that after they reset the system everything suddenly was fine. Maybe Nvidia hidden data trying to prevent AMD running fine on it. Sounds strange? But it could be real. Could be a conspiracy theory or something I think Nvidia would totally do. And about those fan profile issues: check on what setting the fan is in the drivers. Maybe hand tune it, if nothing else works."everything was addressed" and "everything will be fine" essentially means "things were broken" and "not everything is fine".
Coming from 7 years of Nvidia (980ti, Pascal Titan X, 3090), the 7900 xtx experience is definitely a step down in quality/polish. A couple of days ago I went into Windows Display settings to enable my 4k TV (connected but disabled when not in use). My screens blinked a bunch of times, then the system became unresponsive. Rebooted and was back to the default windows VGA driver. Thing crashed so hard it screwed up its own drivers and I had to reinstall Adrenaline. I've done that hundreds of times on previous GPUs and never had a problem, and every other time it was fine on the 7900 xtx other than an unsettling amount of screen flickers before settling down. The fan curve is also odd and seems to have two modes, "jet engine" and "silent", which don't seem to necessarily correlate to GPU or Junction temp. Witcher 3 still crashes in seconds on my main monitor but can run for hours on the TV.
Nothing dealbreaking but definitely some weirdness that does not inspire confidence
