Which Tv Is best ?
Discussion in 'Audio/Video & Home Theater' started by Durvelle27, Dec 7, 2012.
  1. NutBucket
    NutBucket Lifer
    Aug 30, 2000
    25,399
    100
    Native means it can only output 640x480. Even at 12.5' its gonna look like crap.
  2. Durvelle27
    Durvelle27 Diamond Member
    Jun 3, 2012
    4,102
    well could you throw out some suggestions
  3. NutBucket
    NutBucket Lifer
    Aug 30, 2000
    25,399
    100
    Something like this would be bare minimum IMHO:
    http://www.newegg.com/Product/Produc...82E16824009223
    Of course, you would also want to make sure that the room has proper light control otherwise the picture will be washed out. I think given your budget it will be hard to get a decent projector setup. I would stick with a flat panel. If you want big, find a used DLP TV.
  4. Durvelle27
    Jun 3, 2012
    4,102
    Light isn't a problem and projectors seem to fit right in this setup to me
    #29 Durvelle27, Dec 13, 2012
  5. cheez
    cheez Golden Member
    Nov 19, 2010
    1,420
    I tell you what's still the best TV to date: 2004 tech Panasonic TH-50PHD7UY.
    Man, talk about bump-mapping where the 720p Panny's excel...;)
    [​IMG]
    This damn TV is a tank! It's nearly 9 years old, not a single hiccup. Japanese capacitors = Highly trusted
  6. Durvelle27
    Jun 3, 2012
    4,102
    is 105" adequate for a the Acer H5360 mounted on the wall 13 feet away ?
