master_shake_
- May 22, 2012
- 6,425
- 292
- 121
Second one is only a GbE transceiver, so that won't work. 10GbE transceiver modules may be more expensive.
my bad still could just use sfp cables.
1 Gbe sfp's over glass are not wanted as much anymore IMXP, so cheaper, a 10 Gbe sfp will be more $.
As far as the infiniband thing, research wisely. I haven't seen Infiniband anything in a small/medium business environment. IMXP, it's still isolated to the enterprise market. (that doesn't mean it's not, I just haven't seen it yet.)
Infiniband is likely to cost you as much as 10Gbe
As for noise, most of us don't actually need big enterprise servers and switches. We just need something that does this occasionally, so heat is not as much of an issue. In fact, I bought a SOHO 1U GigE dumb switch just because it was on closeout and installed it in my house. But it was a bit louder than I hoped. Given that it is only to support a house, I simply disconnected the fan and tested it. It barely even gets warm the way I use it. I've had it running for 5 years with no problems whatsoever. Obviously, this is not recommended, but I'm sure that in 2014 it would be easy for companies to produce products for the mainstream consumer that could function like this fanless, or compact models with quiet fans, given the lesser needs that most consumers have.A lot of the newer servers/network equipment are actually very quiet. The "newer" (been like 4+ years since I played with them) dell 1U's are ridiculously quiet. It was sitting in the office and I kept thinking it was off. The last two servers I bought (Supermicros) for home are also very quiet, but not as quiet as that Dell one. My last server is a 2U and it's about as loud as a typical workstation so not quiet but not a jet engine either.
Either way noise is not really an issue as server stuff is typically in it's own room. My server room is fairly loud but it wont be too bad once I drywall and insulate it. At work (Telco CO) some of the walls have like 3 layers of drywall, I think that's more a fire code thing but wow does that ever block sound.
SOHO 10GigE equipment will be sufficiently common before 2020 IMO.For those of you wanting consumer 10ge I remind you that you are the exception rather than the rule. Most home users are more than served by a 100mb device, 1gb is more than they use and 10gb is just a waste for them.
Lets face it, a very large percentage of people use their home network solely for internet access.
That being said, if you part of that minority of folks that actually need/want 10gb you are just going to have to pony the cash for business gear because there is little incentive for the manufacturers to cannibalize their business market by releasing consumer gear @ 10g
You'll have to provide more about your environment.
1. How many machines on the network?
2. What OS's supported?
3. Actual real world throughput?
4. Configuration variables?
ETC....
like I said, IMXP, it's isolated to the enterprise market. I have not seen it outside of that environment yet.
4 computers on my ib network
Windows 7 and whs2011 are the operating systems are where they are being used.
They are also supported by esxi.
Throughput is about 300 MB per second that's copying from
from raid array to raid array.
From ssd to raid away its slightly slower.
Not sure what you mean by configuration variables.
I also think before 2020 we'll see consumer desktops with 10GigE.
That's fine for us end users who don't want to deal with enterprise equipment.
Sure it will, thats 6 years from now and business will be on 40G+
Drebo, I know this is off topic but do you have anything about why BYOD is such a big thing. I keep reviewing it and even the big companies like IBM and HP simply state that "most organizations will not save money with BYOD" etc. The most BYOD we have been willing to do is email here because there has a negative ROI on doing it everything else. We are getting rid of VDI for the same reason. Every analysis we have done so far shows no value (among a couple of organizations.)
"Cloud" for small biz I can see but I find that the same small biz that won't spend $50 for an application are normally the same Biz that resists paying $50 month for Internet (but are the first to scream how many $thousands they are losing with the net being down) so I am not sure how well it will pan out yet.
/endofftopic
BYOB is big because people want their devices esp. phones.
http://www.redbooks.ibm.com/redbooks.nsf/RedbookAbstracts/tips0749.html
speaking of 40gbps :biggrin:
that particular page eludes that it's only supported in their clustered solution.
things to note, however:
-supported in xseries (x86) systems
-available for rack mount, not blades.
-supported OS's are SUSE or Red Hat (i'm sure you can buy the card from a different vendor for use in other systems, and it won't matter where you get it, it will be pricey but maybe even on par with 10 or 40 gbe)
IBM uses Inifiniband in quite a few data center solutions
im curious ch33zw1z what is it you do for a living?
hardware field support for....computer gear of all kinds! It's a cool gig for the most part, I get to see all kinds of stuff, old and new, cheap and mucho bucks.
Well yeah like I said "other than email." However new regulations is eroding even that. BYOD now is demanding MDM which tends to eat up any savings pretty quick. It gets to a point where you we might have to talk about "not caring" that someone has to carry an extra work phone.
man that sounds awesome...
wish i would have got in to that field instead of automotive tech.
There is going to get to a point where they will figure it out and you can bring your own device.
It's going to happen.
One may have to give up some privacy/access into their own device to do this, but it's going to happen.
At lower levels, probably too expensive. However; major colleges and organizations (we are Cisco's #1 partner in all technology awards), are adopting this.
We were part of the wireless NFL initiative that was originally deemed insecure, but now everyone is using tablets on the sidelines and sometimes on the field.
There is still a lot of paranoia out there.
In reality, I am sure we are all being seen no matter what device we are on.
