Originally posted by: redgtxdi
Yup........it's a catch22! My advice.................stick with your $200 27" CRT & laugh all the way to the bank!!
I just picked up a 30" Sony HDTV for $200 used. Was that ok?
Do they even make 42" 4:3 TV's?Originally posted by: PizzaDude
Originally posted by: purbeast0
OP ... you DO know you don't HAVE to stretch the 4:3 to fit the 16:9 picture, right? please tell me you know this ...
and redgtxdl ... your TV must have sucked. first of all, you got a plasma. plasma's are the bottom of the barrel as it is (consiering I am assuming you didn't get a top of the line one, considering you think a 27" CRT looks better). sure a 50" picture at normal SD resolution will not look as crisp or clear as the SD picture on a 27" picture. Just like a game running in 800x600 on a 15" monitor will look better than it would on a 24" monitor. If you don't understand why, then I guess it makes sense you are complaining.
at 27" your TV still has all that noise on the picture and looks like crap, only since the image isn't blown up to 50", you don't notice it.
Yes...I know that, but then WHY get a widescreen TV and have two black vertical bars on the sides!???
Originally posted by: Thraxen
Originally posted by: vi_edit
Take an MPEG movie that had a native resolution of 640x480 and then blow it up and run it 1024x768. It looks worse at that resolution than the native one.
Same concept with SDTV on an HDTV. You can tweak it a bit to help. But the point still remains that unless there is some very high end upconvert on some TV's that I'm not aware of, you simply can't make up resolution on SD content.
Maybe that's the difference. I have a couple of CRT HDTVs. I know for a fact that the main set doesn't upconvert and not being DLP, or anything else with a native resolution, digital cable looks pretty much identical to how it appears on our SD sets... in fact, it may even look better.
Originally posted by: Jeff7
There are going to be some protests if this happens. My dad is among the crowd who says "What are those black bars? Get rid of them!" when he sees a widescreen DVD. He will not watch a movie that is widescreen format. He just can't stand it, he says that "the black bars are too distracting."
I meanwhile hate letterboxed versions because they chop off about 25% of the movie.
It doesn't chop off any of the picture, it's just formatted differently so you can use the whole screen. I have a 4:3 TV right now and would much rather watch a fullscreen dvd because then the picture is a full 27" instead of having the "distracting" black bars...
fullscreen = pan and scan.
congrats, you're losing 43% of the picture :thumbsdown:
What are you talking about? There is nothing cut off when you watch a full screen dvd...
How big of a CRT? IMHO, the bigger the screen, the more visibile flaws become. If it's a 36" CRT it will be more forgiving on the eyes than a 50" screen, all else being equal.
Admittedly, I only have experience with RPTV and Plasma HD sets. I haven't had any extended viewing time with a CRT HD and how they work with SD content.
Originally posted by: notfred
I don't know why black bars bother people. They're equally as distracting as the black and/or silver frame around the whole picture that is the edge of the TV. That is to say, not at all.
I din't buy no fifteen hun'red buck fandangled tv set just to have half it covered in them there black bars! I want to use the whole dang screen damnit!
Am I missing something here?
Also, can you clarify what pan and scan is?
Uh, Yes. Yes it does.
Here's a quick example: <a target=_blank class=ftalternatingbarlinklarge href="http://
<b">Star Wars Chop Job">http://ww...reen.org/examples/starwars/index.shtml</a>
Pan and scan takes part of the image, crops it and zooms in on it to make the picture 4:3. Ever notice how the movie screen is a rectangle and your tv is a square?
<b"><b">Star Wars Chop Job">http://ww...reen.org/examples/starwars/index.shtml</a>
No, but I've noticed the difference between 16:9 and 4:3. 4:3 is not a square, hence the 4:3 ratio...
Scroll up Dr. It is just you and I left in this world.Originally posted by: DrPizza
I must be among the relatively few who realized the majority of content was 4:3 - i.e. television broadcasts. So, I bought a 4:3 television
Yes, there are 40+ inch HDTV's with a 4:3 ratio; not all HDTV's are widescreen.
Now, when purchasing movies, I always buy the widescreen version so that I get the entire movie, not a cropped movie. I don't have a problem with the black bars on the top and bottom, because it's a big enough tv.
Originally posted by: lokiju
You must have been using standard cable or over the air standard def channels then, I have DirecTV and the standard doesn't look nearly as bad as the standard cable that I had prior to it looked.
Not all SDTV looks like crap on an HDTV. Digital channels look just fine. Sure, they don't look as good as HDTV, but they don't look any worse on an HD set than a non-HDTV.
Originally posted by: Special K
Why can't the filmmakers start producing movies in a 16:10 aspect ratio so that people with HDTVs can use the whole screen?
Same answer applies here.
