Thin criticisms? I made them about as blatant as I possibly could.
I hope it is EXTREMELY clear how I feel about you. In years of being a regular in our garage, this is by FAR the most dangerous thing I have seen anyone do. And the worst part? It was completely intentional. You clearly 'know enough' to know better. We have had plenty of people unknowingly do stupid things, but what you did was COMPLETELY intentional.
You are an ignorant, lazy, selfish asshole. You knowingly drove around a vehicle that endangered everyone around you. You then pulled over, saw it was worse than you thought on the 'first' ignorant drive, and you then proceeded to drive around with TWO LUGNUTS.
Report me for hurting your feelings??? You go right ahead. You need a wake up call better than anyone I've seen in a long LONG time.
You could have KILLED somebody. I don't care what your spoon fed, ignorant, selfish excuse is.
You absolutely deserve to have your little "feelings hurt".
My God, the little careless errors that turn into nightmares. It's happened to me so much. I've had to learn a lot of lessons the hard way.
Got a good one for you guys. I drive an International truck with a 24 ft refigerated box that goes out in the morning full, like 18 tons full. The day before I drove the truck, one of our mechanics repacked the bearings on the front wheels after doing a front brake job. Apparently, Methhead Mike forgot to put grease in the passenger side bearing. Guess what? About 20 miles from my warehouse, at 3am, I feel a crazy jouncing sensation. I hit the brakes just as the entire wheel assembly, brakes and all, got cut off the axle when the bearing finally seized. Truck left about a 200 ft gash in the roadway. Luckily I hit the brakes as hard as I could and the truck ground to a stop on the edge of a 10 ft ditch. Cops were amazed I didnt flip the truck and get killed. Pretty interesting to see the drivers side rear wheels about 3 feet off the ground while the passenger front axle was ground into the pavement, like 4 inches.
Peace
Lounatik
FYI - it looks almost like there is a notch behind that hub that you can get to the back of the studs from (right side), but I could be wrong. If there is, line up the hub so one of the studs is lined up with the notch, smack the end of the stud with a 2-3 lb hammer a couple times, and it should pop out. Rotate the hub to the next and repeat. Don't bash it too hard as you don't want to damage anything like bearings or the hub, just knock the stud loose.
DO NOT REUSE THAT LAST REMAINING STUD. Replace all 4 of them.
I've used a ratchet and a lug nut to draw studs into a hub before. Little chance of overtightening and damaging either the lug nut or the stud doing it by hand.
Huge +1 on that, the remaining stud is likely bent.
Quoted and reported to a moderator for thread crapping.
Hopefully, the mods are smarter than you.
Not to berate the point too much, but there's really not much of an excuse to make a careless error other than being careless (i.e. not caring at all if you're doing it right). There are a zillion how-to videos and walk-throughs on basically every fix you'd ever want to do available for free on the internet. Repair manuals can also be found for free or cheap. Heck, some libraries even have Haynes manuals that can be checked out. The only reason one wouldn't have these resources on-hand when working on a car is laziness and carelessness.
You're posting on an internet forum, clearly you have some internet access. You really have no excuse about not knowing how to replace a wheel stud. You also have no real excuse about not knowing how to replace the front strut. Literally 3 minutes and 30 seconds of video that would have showed you exactly what you needed to do, saved you a bunch of time and aggravation, and prevented you from driving around in a VERY unsafe condition. Both videos are literally the first results that show up if you had bothered to google what you were working on. If you had spent 4 minutes up front with google and YouTube you would have saved yourself a bunch of time, made your life suck a whole lot less, and kept you from endangering other people.
I am not insulting nor attacking you, I am simply pointing out how little effort it takes to avoid "careless mistakes" and to ultimately make your own life easier and other people safer.
Risks to your own person/equipment/car/wallet are one thing. Knowingly endangering other people involuntarily is entirely different.
When I double-check my work on my car I sit there and think: if a family of four is in the oncoming lane, and what I just worked on isn't right and fails, what happens? Then I go back and triple check everything.
If you ever think "I could have benefited from researching this task more before starting it" you are taking/already took an unnecessary risk. End of story.
You are indeed careless. You drove with 3 of 4 lug studs for 1,000 miles. That is quintessential carelessness. The fact that you think you "take every precaution [you] can" is scary because you are flat wrong.
Being conservative does NOT mean being paralyzed by fear. It means honestly evaluating your skills and knowledge and double-checking when you need to. You apparently have absolutely no technical knowledge or prior experience to properly evaluate if 3 lug nuts would be sufficient. Yet you lied to yourself, you convinced yourself that you were qualified to make that judgement, and you are not. That is what is most upsetting.
