whats wrong with Mac's?
bluestrobe
2,033
Originally posted by: Thin Lizzy
To run xpostfacto you need to have OS9.2.2 installed, which is another "restricted hardware" OS Mac has to offer. So you have to find a hack for that too.
Not true. The minimum to run XpostFacto is 9.0 Want proof?
I quote:
XPostFacto does not run in Mac OS 8, so you need to have at least Mac OS 9.0 installed to use it. XPostFacto will run in Mac OS 9.0, 9.1 or 9.2. (It requires Mac OS 9.x in order to be able to copy files with long filenames from the Mac OS X Install CD to your hard drive).
Here is the page where I got the info from
I recommend having OS 9.2.2 for Classic, because some apps require OS 9.2.2, but you do need a hack to run OS 9.2.2 on legacy macs. But you do not need OS 9.2.2 to run Xpostfacto.
Xpostfacto will run on anything but from what I researched, you need the OS9.2.2 install dialog to start the installation process of OSX. This was awhile back though and maybe its not needed that way anymore.
imported_Lucifer
5,139
I have never used Xpostfacto, so I am not sure. I just got that info straight off the Xpostfacto page. I was about to use it once on my PM 9600. It was using OS 9.1 and it was going to let me install it, but I didnt due to limitations, such as loss of serial ports so I wont be able to use Personal Laserwriter. Also the slow bus speed, which was stuck at 50mhz. And the internal floppy drive would not have been usable. I decided to stick with OS 9, and it did serve me well. Sadly, I no longer have my PM 9600, because I sold it for a good amount of money. :)
Dennis Travis
You can for sure use OS 9.1 to run Xpostfacto. I did it before I got my G4 with my 7600 with Sonet G3 card. Worked great and I was able to install OSX Jaguar. I don't know about anything older than 9.1. I am sure the Xpostfacto site will tell you what revisions of the OS it will run from.
