What's a hole saw?
paperfist
6,539
287
www.the-teh.com
It's the tool that attaches to a drill that will cut out 1/2", 1", 1.5", etc holes, right?
Is there another tool with the same name?
I ask because I went to the big box store to get something to cut out the area in the counter top for a drop in sink. I wondered if the router bit I had selected would work since the jig saw I am trying to use cuts anything but straight. The guy said a hole saw would work better. I walked away perplexed.
So I asked another guy there if the router bit I selected would work. He said sure, you can even use it in a drill if you don't have a router....
NutBucket
27,152
635
You can use a jig saw. It sounds like you're doing a top-mounted sink into a laminate counter? If so, whatever radius you need for the corners can be done with the jig saw. Plus, the rim of the sink will cover up any....irregularities in your cut.
boomerang
18,883
641
A jigsaw blade with dull teeth on one side will be bear to try and get a straight cut with. If that's not the case, you're the one guiding the jigsaw. ;) It should cut where you guide it. The only limitation is the size of the radius you can cut and that is dependent on the width of the blade.
Binky
4
I can't say that I've seen a hole saw large enough to fit a sink in the hole. ;)
boomerang
18,883
641
No kidding. But I think something is being lost in translation.
A hole saw would of course cut some very nice corners for a sink opening. That might be the way a homeowner that only does the occasional project around the house would approach the project. I can't see that same homeowner free handing with a router though. The router bit portion just confuses me.
paperfist
6,539
287
www.the-teh.com
I think he might of thought I just needed to drill out for a faucet. I didn't have the heart to continue the conversation.
I'm using a pretty new Black and Decker jig saw with a new blade for laminate work. I think something is wrong cause the blade keeps coming off the guide wheel. I even have a guide setup to cut against and it keeps wanting to go left away from the guide. Very frustrating!!
I was tempted to buy a new jig saw for $150 but I use them like 2x a year. I bought a flush cut router bit and going to try that out.
paperfist
6,539
287
www.the-teh.com
Yes, top mounted sink onto laminate counter top. There is a bit of overlay, but not much at about 1/2". I'm not really sure why the jig saw is fighting me so much.
I already drilled out the 4 corners so all I'm trying to do is make 4 straight line cuts.
MongGrel
38,466
3,067
121
A hole saw in the 4 corners would be ideal with a template and lay the centers out. And cut straight lines to them with a jigsaw.
Hole saws run a bit.
It sounds like your trying to force the jigsaw to cut too much, let it cut and don't try to force it ahead.
Maybe try putting light oil on the blade a little even, lard would even work.
A laminate blade after rereading might be your biggest problem, laminate itself isn't thick, is it really fine toothed ?
Might need something a bit larger toothed.
NutBucket
27,152
635
I think the laminate blade may be the problem. I would try a blade designed for wood. Apply painter's tape along the cutting path and that should help prevent the laminate from chipping.
paperfist
6,539
287
www.the-teh.com
Thanks I'll try the oil. I do have a death grip on the jig saw because there's not much of an overlay and I don't want to stray off the cut line too much.
Plus the sink is massive and after the cutout there will be less then an 1" in front and in back of the sink. The core is crappy 3/4" partical board and I don't want to undermine what little structural integrity it has.
Yeah the blade is fine, really fine. Forgot how many TPI.
paperfist
6,539
287
www.the-teh.com
I have the tape laid out already. I'm just worried that the laminate will split. I'm not sure that could actually happen.
paperfist
6,539
287
www.the-teh.com
That or borrow a Sawzall from someone and go to town :p
HA! I have one and am really, really tempted to use it with a metal blade.
My GF picked out the most beautiful counter top set on the crappiest piece of partical board they could find. I'm thinking the vibration from the saw will crack it.
This shouldn't be this hard. I cut it to length already in 2 minutes with a circular saw and zero chips. The damn saw is to big to cut the sink part out though :(
herm0016
8,516
1,128
Use a coarser tooth blade. That should get you going, and don't force the work.
NutBucket
27,152
635
You can reinforce the opening to help support the weight of the sink it you're concerned.
Greenman
22,292
6,461
They make jig saw blades that cut on the down stroke instead of the up stroke, that prevents chipping. If the blade wanders a lot you either have a very cheap blade, or a crappy jig saw.
paperfist
6,539
287
www.the-teh.com
Thanks.
Does that type of blade have a name?
I'm guessing the jig saw is crappy. It wasn't cheap, but it's a Black and Decker that doesn't seem too well built.
The blades are name brand and around $10.
twinrider1
4,096
64
:D
Greenman
22,292
6,461
Thanks.
They're called a reverse tooth blade. Sometimes things really do make sense.
You have to cut slow, and keep down pressure on the saw, otherwise the blade wants to ride up the material you're cutting. It's the exact opposite of how the tool was designed to work.
http://www.amazon.com/s/ref=nb_sb_s...saw+blade&sprefix=reverse+tooth+jigsa,aps,253
