Originally posted by: aigomorla
Originally posted by: Idontcare
So why do we have 4GHz 150W Nehalems instead of 0.1GHz 1kW Nehalems?
i thought the .1ghz 1kw nehalems were called itaniums. 😛
Pretty sure you are getting that confused with larrabeast now 😉
Originally posted by: Soleron
Well, AMD's technology development is behind Intel's for sure, that's not a technical decision. That's likely because they have less capital to throw at it, and less volume to make up the capital costs.
What I'm trying to say is that AMD could launch a 32nm chip now. It would have sub-10% yields, be leaky, poorly-clocking and all-around inferior to 45nm, and it would cost several times as much per good die to produce. But it could be done. So there must be a point at which it goes from being uneconomic to do a 32nm chip to a good decision. And I think when GF talks about Q3 2010 as "risk production" and "volume ramp" they are referring to a technical position, which is unlikely to be when retail chips are viable. Look at when TSMC announces processes - 40nm was "ready" in late 2008, but the first retail chips in any quantity are in September this year.
I'll make another point against 32nm Deneb, which is that every dollar and man-hour you spend on it is less to spend on Bulldozer. And Bulldozer better be perfect and on time.
...we should know for certain either way on the November Analyst Day.
That said, I have no insight on process technology beyond what tech reviewers, news reports, and JF say. If you know that AMD's process technology can launch 32nm Denebs profitably in Q3 '10 then I'd love to know about it.
Soleron your points are valid, I hope you aren't getting the feeling that I am in violent disagreement with them or some such.
I've long held the perspective that a 32nm Deneb shrink would just be a needless distraction of AMD's already diminished R&D resources and that they needed BD sooner than later. But look at what they did at 65nm, the last time they introduced a major architecture change, they dragged the Athlon X2 into 65nm a year before Phenom came out.
BD is set to make the same 1yr stagger release, so the question is why would AMD not plan for a Plan B by shrinking Deneb/Thuban? I had ruled it out as an unlikely drain on R&D resources until I heard them confirm they did shrink the Deneb core logic for Fusion...well if they shrunk it for Fusion and got the layout and everything tweaked then it is truly a minimal cost adder at that point to hack off the GPU in the layout and just spin the reticles for a stand-alone 32nm Deneb shrink.
At this point I'm not trying to argue that they should, I am arguing that I can't rationalize how they could justify not going that one extra last step at minimal cost and by doing so have a backup plan to any snafu's or delays in 2011 with BD.
If we think AMD is in for some rough times in 2010 with their 45nm Stars Core based chips fighting off Intel's Westmere based 32nm chips then what do we think 2011 is going to be like?
Absolutely implausible to me that AMD would expect their shareholders to find it OK that AMD's decision makers decided 45nm K10.5 cores would be good enough for 1H 2011. Those decision makers have something planned for 1H 2011, and if its not BD then it only stands to reason that it will be a deneb shrink with that fusion IGP lopped off (or perhaps just disabled if it isn't too big of a diesize hit).
