Originally posted by: SynthDude2001
:heart: 1680x1050
:heart: 1680x1050
Originally posted by: Trikat
Why is the most common resolution used on the very bottom of the poll? Did the OP forget to put the most common resolution in there and finally added it in later?
Almost didn't see it at all...
<- 1280x1024 on a 19"
same.
Though the standard in the general population is 1024x768, due to all the noobs still using 17" CRTs (okay, by noobs I mean older people).
Biggest computer fallacy of all time. CRTs have this little buttons/dials that adjust the height and width of the image. Thus, CRT images are almost always not 4:3. The chance of you having it adjusted to exactly 4:3 is slim to none - unless you actually purposely measured the image size. And face it, the general population does not measure the image to ensure it is exactly 4:3. Since the image isn't 4:3, why must the resolution be 4:3?Originally posted by: dug777
you are aware that is an incorrect aspect ratio for a CRT i hope?
you should be running it at 1280x960.
if you want to retain the correct aspect ratio.
