Originally posted by: Howard
Yes, that's the idea. I do have a hot-glue gun, but does hot glue damp sufficiently?
Originally posted by: StevenYoo
Discontinue use of Silicone Caulk if any of the following occurs:
? Itching
? Vertigo
? Dizziness
? Tingling in extremities
? Loss of balance or coordination
? Slurred speech
? Temporary blindness
? Profuse sweating
? Heart palpitations
That's the Happy Fun Ball (I think) thing, isn't it?
Originally posted by: mercanucaribe
You can't use it to perk up your girlfriend's breast implants if that's what you're wondering.
Originally posted by: Fritzo
I would not use it on silicone breast implants.
Brilliant! Thank you.Originally posted by: MS Dawn
Hot glue shouldn't be used for anything permanent. It is semi-rigid but has major thermoplastic characteristics which make it fail quickly at even normal component operating temperatures. Its bond strength is also considerably weaker if it's applied to a cold, smooth surface.
What you can do is RTV a sleeve in place for shock mounting and once the RTV is cured sufficiently where there's little release of acetic acid you can epoxy the electret in the sleeve. This will provide isolation with minimal risk of chemical attack to the element.
