What makes tires blow in this manner?
Originally posted by: Skoorb
Originally posted by: Roger
I have to emphasize the fact that it was not a single hole but evenly distributed around the entire tire's sidewall.
The belts in the sidewall seperated which caused the failure Skoorb.
OK 🙂 So it was just a manufacturing defect freak occurance sort of thing...I suppose perhaps I should change the front tires, but I had to spend $310 on the two new rear ones yesterday 🙁
How much was labor? The tires cost $250 total?
Originally posted by: Ornery
Not true. Right rear blew out on my '77 Town Car at about 80MPH, and the only reason I knew was because the carcass was flapping against the inner fender well!
Hmm, so presumably it blew the 5 minutes before. Not sure what the second sound was 🙂
It was a maxima to answer the question below.
The tires were $310 with labor included. The tires were about $129 each or something like that. I opted againgst buying a road hazard warranty at $10/tire. Tirerack had them much cheaper, of course, and in the future if I have time or I'm buying an entire set of tires I'll be sure to order them from tirerack instead of paying top dollar at a tire shop.
Originally posted by: LAUST
I think the problem lies in the car that the tires are on 😛
J/K 😉
Don't retract the comment - I think you're quite right. I have seen that some drag cars actually have additional bolts connecting the tire to the rim so that the torque doesn't spin the wheel independent of the tires. I suspect that I probably need to do this myself.
nitto actually makes very decent tires. I have nitto-555's right now, and have used the 450's.. both very good high quality tires.
