Originally posted by: MikeyIs4Dcats
hell, there is even an instance where a man was killed by a 9 volt battery.
A 9V battery cannot electrocute you from outside your body. It's pretty much impossible - unless you have a serious heart condition, or possibly, some sort of implant like a pacemaker.
The electrical resistance of the body is way too high (even with internal electrodes), unless the electrical current is delivered by electrodes touching, or inside, the heart.
Now, the story as you retold it sounds impossible, but the actual story is slightly different. Said person managed to electrocute themselves with an ohm-meter that they were using to check electrical cables. Ohm-meters for electrical insulation testing, while they may be powered by a 9V battery, actually step the voltage up internally, and typically test with 500 or 1000 volts. Said meters are potential hazard even when used correctly, and if misused can easily cause electrocution.
