This is akin to the Camry guys saying their car is just as _adequate_ as a bugatti veyron day to day.
who was that guy with the camry or altima or something that had like 200hp that was talking about how awesome it was?
What does the turbocharging cost relative to the NA engine?
Let's compare two Accords. The EX and the EX V6. What does it cost to get the EX up to the EX V6's power?
You need 81 more horses and 92 more lb ft of torque.
Go!
Honestly I think the only reason the 0-60 times are so close is it's hard to lay that much power down. I bet with a longer swingarm the 600s would pull away harder.
Some guy: THERE IS NO REPLACEMENT FOR SUGAR
Shawn: What if I try baking a cake with Splenda instead of sugar?
LTC8K6: What does Splenda cost relative to sugar?
In response to your question, Splenda is more expensive than sugar.
Nope, it's as simple as that. Some companies go with displacement, some go with forced induction.So, you can't just replace the V6 with a turbo 4 then? There's a bit more to it than that?
Honda --> displacement (I4 and V6 accord)
Toyota --> displacement (I4 and V6 camry)
Subaru --> turbo (NA Impreza and turbo Impreza WRX)
Audi --> turbo (everything is turbo)
Cadillac --> both (supercharged V8)
The Chevy Cruze is an interesting example. Base model is a 1.8L engine and something like 140HP or whatever. The higher up models are 1.6L turbo and they make the same power. They really did replace engine size with turbo and say it's the same; Chevy did exactly what hillbillies said could not be done.
How about the ford ecoboost v6 that are outperforming the 4.6 V8s in both performance and fuel economy?
Ecoboost is making 700 hp? Since when?
Ecoboost is turbocharged and can only be compared with turbo or supercharged 4.6s if you want a even comparison.
Eh, I disagree. A lot of turbo engines are meant to drive like bigger engines with more cylinders. Ford even markets the TT V6 as a V8 replacement.
Ecoboost is turbocharged and can only be compared with turbo or supercharged 4.6s if you want an even unbiased comparison. As for fuel consumption, obviously 700 HP will consume twice the energy than 350 HP, regardless what size engine makes D:it.
I don't see anything on the ford website that does anywhere near 700HP.
6.2L natural aspirated V8 only does 411HP. Are you talking about the engine in a large yacht or something?
You can't compare a blown small engine to a NA large engine. Either both NA or both blown. To ignore this condition is to disbelieve the truth and arrive at the predetermined and false conclusion you want to see.
If you are going to compare an Ecoboost to a 4.6, it better be an 03 Cobra 4.6 running the same boost psi. Otherwise you might a well be comparing the Ecoboost to any arbitrary engine such as a mower from the 50s and concluding how much better it is.
"My car is faster than your bicycle" is not a fair or valid scientific comparison. When comparing a single claim, such as "smaller engine can make same power as a big engine", all other factors that affect power OTHER than displacement must be held constant and equal.
You cant just force 30 psi into the small engine and 0 psi into the big engine and make a claim that displacement doesn't mean anything, because you know damn well what the outcome would be if you also forced 30 psi into the bigger engine too. :awe:
Can we rev your forced induction 4.6l V8 to 18,000 rpms and compare it to a 2.4l naturally aspirated Formula One V8 engine?![]()
There isn't.
Take your boosted, overhead cam, vario this and that, 15k RPM engine that makes 300 HP / L but is only 1 liter.
Now make it 4 liters, without changing anything else. Now you have 1200 HP. Get it?
Anything you can do to a small engine you can do to a big engine.
Formula for engine power output:
power = (technology+boost+exotic materials+this+that+electronics+unicorn blood+RPM+balls to the wall every last bit of power per cubic inch you can possibly get with current design and materials) x displacement
None of the things in the parenthesis are "replacements for displacement" because their application is independent of displacement and can be implemented with equal effect on engines both large and small.
Seems you're a little vague on English. There is indeed a replacement for displacement. Forced induction, higher rpm's, variable valve timing. All of those things will get more power out of an engine, without increasing it's displacement. I don't see how the concept could be simpler.
"there is no replacement for displacement" literally means that there's no possible way a smaller engine could ever generate more power than a larger engine under any condition. That's literally what you are saying, and the rest of us are saying that is incorrect and we've given several examples to support this claim. A 1986 Pontiac with a 5L V8 engine has less power than a 2011 2.4L Honda Accord. Honda somehow managed to increase power without increasing displacement. You're trying to tell us that they did not "replace" any other thing related to the engine that would have the same effect as increasing the displacement? Really???You cant just force 30 psi into the small engine and 0 psi into the big engine and make a claim that displacement doesn't mean anything, because you know damn well what the outcome would be if you also forced 30 psi into the bigger engine too. :awe:
