- Apr 14, 2001
- 57,483
- 20,007
- 146
I'm not so certain some of those fears are irrational. If they were, I doubt states would be passing anti-thimerosal legislation.
Yeah, and irrational fears over silicone implants didn't bankrupt Dow Corning either, right? :roll:
There is no valid scientific evidence for the proposed bans on thimerosal. They are simply knee-jerk reactions to fear mongering.
http://www.cdc.gov/nip/vacsafe/concerns/thimerosal/faqs-thimerosal.htm
You may want to go back a bit and take a look at how well connected the leadership of the CDC is to the major drug companies. I'm not saying that there are clear links one way or the other. I'm suggesting that way more research needs to happen to examine the possible links, and the CDC is unwilling to promote this kind of research.
This is always the first response and it's sad. Typical Mercola propaganda.
Let me put it this way: There are no valid, peer reviewed and repeated studioes showing harm. None.
Maybe this would have something to do with the fact that the CDC will not release valid data to independent researchers.
Was this while they were on the grassy knoll?
Awesome comeback! Way to further your case.
You might want drop out of your debating club.
You might want to make a valid argument instead of mindlessly parroting paranoid propaganda.
My argument isn't valid to you simply because you don't agree with me. I've taken the time to view both sides of this issue. As I had stated in a previous post: I'm not saying that there are clear links one way or the other. I'm suggesting that way more research needs to happen to examine the possible links, and the CDC is unwilling to promote this kind of research. If I wasn't stuck at work today, I could come up with citeable proof of this statement.
Instead of backing up your position with anything valid, you resort to snide remarks. This debate has no further interest for me. I thought there would be some intelligent discourse on this. I was clearly mistaken.
The problem is you offered up a long parroted conspiracy theory with absolutely no valid evidence to support it.
And I've seen your side of the argument. It's invalid because there is no valid proof to support it. None whatsoever.
I DID back up my position with facts. You countered with unfounded conspiracy theories and tin foil hat claims.
