Originally posted by: mitchafi
Heh, I know I downloaded the program from memtest86.com. I just don't know what program to use to burn the .img iso onto a cdrom. Nothing seems to support burning of .img's. Nero definitely doesn't appear to.
Sure, you could ignore P95 if you want. Personally, I would at least like to know what is causing the failure though...Originally posted by: mitchafi
So say I just forget about this and continue using my PC even though it fails Prime95's torture test miserably. Will running my PC like this damage any components or do damage of any kind. My PC has not crashed once except when I overclocked it too high and it feels perfectly stable to me. But what I want to know is if it could cause any irreparable damage that would make this worth getting to the bottom of.
Originally posted by: JustAnAverageGuy
perhaps the ISO would work better for you.
no need to get hostile Sid. I did that, and even selected ALL FILES, then burned the .img, to no avail. But I will try renaming it to an .iso I never considered that. Btw is the v-dimm voltage neccesary called that? I didn't see it in bios but I saw v-link, DDR, and some others..
