Originally posted by: Crappopotamus
overdrive is like an afterburner on a plane, which is similar to nos. its also got parts of a vtec setup. ive actually got an upgraded ecu od, ported and polished. my car is so fast with it on. yesterday i smoked a corvette, and he was all like 'oh snap i dont have overdrive thats sick yo'.
so basically, if you want to be fast and impress the chickas, keep your overdrive on.
hahaha what a joke! And afterburners are nothing like NOS, its refueled exhaust from the first burn which is then burnt again.
you dont know what the hell youre talking about. my dad is a race car driver on the nyrus circuit and my mom is a fighter jet pilot. i think i know what nos and afterburners are. n00b.
ps my moms fighter jet is the new model f27b with an upgraded direct port nitrous afterburner.
You sound like a little kid who lives in an orphanage! Good luck with life dude!
Yah, want me to prove it ? I also have 2H, 4L, and 4H to throw in the mix.Originally posted by: Pepsi90919
Originally posted by: rh71
My truck:
P
R
N
D <-- overdrive
L
3, 2, L?![]()
Originally posted by: gotsmack
I have a button on mine for overdrive.
Is it safe turn it on while the car is moving or should I wait until I come to a complete stop before turning it on. I normally leave it off.
You better not be serious.
-Xionide
My truck:
P
R
N
D <-- overdrive
L
3, 2, L?![]()
There are no female jet fighter pilots.
Originally posted by: acemcmac
Originally posted by: Marauder911
Unless you are towing something very heavy, where you need more torque, leave it on. In an overdrive automatic transmission (most commonly a four speed), the first two gears are underdrive (engine turns faster than the rear wheels), 3rd gear is 1:1 (engine turns the same as rear wheels), and 4th gear is overdrive (the engine turns less than the rear wheels). When overdrive is turned off, your car only uses the first three gears. When overdrive is turned on, it will use all four. This means at a higher speed, the engine has the ability to turn lower RPM's, using less fuel.
we have a winnar! :beer:
you guys are horrible at answering questions. 4 posts aimed at me and I still have no answer.
yes or no : Is it safe (for the car) to push the over drive button while moving in an automatic or should I come to a stop first.
in other words, If I drive on the highway non-stop for an hour and toggel the overdrive on and off like 30 times. Will I damage the car?
Hmm... if it were really that bad, do you think they'd allow it to be engaged while the car was in motion ? There's a reason why you can't shift to Reverse without depressing the shift unlock first (meaning you really meant to do it)... every other gear (except for Park) can be shifted to without pushing the unlock first. That's cause shifting gears (4,3,2,1) while the car is in motion is ok... even if you did it accidentally.Originally posted by: gotsmack
Yes there are
You're friggin dense if you couldn't make out the sarcasm in Crappopotamus' replies
Originally posted by: Eli
My dad leaves it off until he gets above 45 in the Camry. I never thought about it.
