What do the "deck height" and "deck thickness' of an engine block mean?
Howard
47,982
11
dartheads.com states their deck heights as greater than 6"... What's up with that?
Heisenberg
10,621
I didn't read your title close enough the first time. Sorry. Block deck height is the distance from the center of the crankshaft to the top of the deck (where the heads bolt on).
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
The top of the engine block is the deck.
Piston deck height is how the piston measures in relationship to the top of the block. A positive deck height means the piston top actually protrudes beyond the top of the head. Negitive means it is below the deck.
Block Deck Height is measured from crank centerline to top of engine block.
deck thickness is how thick the material of the flat part of the block is. usually somewherez around .600ish
Howard
47,982
11
Flat part of the block?
Aside from that, my questions have been laid to rest. :)
