kjboughton
- Dec 19, 2007
- 330
- 118
- 116
RC5 pre-built binaries are now available for download:
https://github.com/freecableguy/v3x4/releases/tag/v0.1b-rc5
includes voltage modifications... get ready for the magic to happen...
I *HIGHLY* recommend ucode 0x1F (27):
http://www.kristech.net/haswell/0x1F.zip
Also, some hints:
-- ENABLE C3
-- ENABLE C6
-- disable QPI Link0p (power savings) if you can
-- shutdown and power cycle PSU between driver changes and repeat attempt warm boots on boot failures... if MB complains of Overclock Failure, enter BIOS, and exit (discard changes) without reboot to continue
-- FIVR settings are retained between warm resets; multi changes are cleared on each boot regardless... this can cause some funny situations... just because a driver doesn't work the first couple of times doesn't mean it won't work and be totally stable at even higher clocks
Also, some hints:
-- ENABLE C3
-- ENABLE C6
