What controls Turbo Core in Xeons?
Page 123 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
reden
Good afternoon! Is there a driver that will make 2690 v3 work on 3.49 in all tests? Because now the processor sometimes drops to 3.38
phyrexiancure
10
I think what your seeing is the processors normal down clocking in certian workloads, it still fluctuates with the mod. Undervolting the cpu's vcore should help cause power usage is a down clocking factor. Undervolting by - 0.070 volts is in the ballpark range to keep it stable.
phyrexiancure
10
Hello, I got a MSI x99A-SLI-Plus with an AMI Aptio V. Is there a guide to do the mod with this type of bios? Is mmtool the way to go, I believe theres a version of it that can mod this Aptio V bios.
Scan409
27
22
41
Hey did you ever get one? I have the same board with a e5 1280 v3
Here is the mod.
Use M-FLASH in BIOS
V3_MOF_705050 ffs + 306F2 mCode removed + Disabled C6 State(in IntelRCSetup) : https://drive.google.com/file/d/1qazvvMw4e58swLXwUGnqd4T8r8StF0R4/
djthrottleboi
8
phyrexiancure
10
Thank you so much as no matter how i did the mod it wouldn't work for me.
Update: It is installed and worksat first but then defaults down to 2.9GHz on all cores. also I get a current limit throttling and it doesn't go away. even at idle I am throttling
I'll try it out and share my e5 2690 v3 results later today.
djthrottleboi
8
yeah let me know if it works what settings you have in the bios as i may have something aset wrong. this board may just be bad though considering I can't get my cards to run at x16. may just have a bad board.
Scan409
27
22
41
Try use Cinebench R15, Prime95 (without AVX, Small FFT’s), AIDA64 Cache & Memory Benchmark
Intel XTU Benchmark is useless for check Turbo Unlock.
Reactions: phyrexiancure
djthrottleboi
8
it works now yes. Btw i have one more favor. Can you do the mod with this bios instead https://download.msi.com/bos_exe/mb/7885v18.zip ?
Any bios after 1.9 is very unstable on my board. I just bsod'ed playing elder scrolls online. that tells you how bad it is.
Scan409
27
22
41
phyrexiancure
10
Thank you so much. Everything is stable and perfect. I'm not sure why it didn't work when I tried to mod it but you got it perfectly.
Here is the mod.
Use M-FLASH in BIOS
MOF_V3_705050 ffs + 306F2 mCode removed + Disabled C6 State(in IntelRCSetup) : https://drive.google.com/file/d/1qazvvMw4e58swLXwUGnqd4T8r8StF0R4/
Everything works fine for me, on cpuz's normal stress test I get the full 3.5 Ghz turbo boost on all 12 cores. Its avx 2 benchmark and prime95 only throttle to 3.4 Ghz. :) THANK YOU Scan409, your a true credit to team.
Reactions: Scan409
Fury13
18
Assume the above modded bios will work MSI X99A Gaming 7 aswell?
They list the latest firmware as 7885vHH2 here:
Will give it a shot when I get some spare time
Scan409
27
22
41
Here :)
Use M-FLASH in BIOS
V3_MOF_705050 ffs + 306F2 mCode Removed + Disabled C6 State
PhotoPrint
Hi all :),
I got the KLLISRE X99Z V102 + E5 2620V3 and I have successfully modded the bios and injected the FFS driver and turbo is unlocked, but I see that many times after waking up from Sleep/Hibernation- that max clock speed is reduced to 2.6Ghz.
Did anyone else got that issue?
I used this guide:
but had to use AFUWIN 5.12 to store and flash bios(it's locked on this board).
Edit:
OK, Just found the solution - it was easy :).
In Bios:
ADVANCED->ACPI Settings:
*Enable ACPI Auto Configuration[Disabled]
*Enable Hibernation[Enabled]
*ACPI Sleep State[Suspend Disabled]
*Lock Legacy Resources[Disabled]
After this I only have Hibernation option but now after waking from Hibernation the TURBO Huck is ON :).
Reactions: Scan409
djthrottleboi
8
what is this in particular? the mod as an official thing with the x99-ud5-wifi mobo?1591860946568.png
EDIT nvrmind. I just seen what it is: trash. I have this motherboard coming. Now i need to remod.
s.anastasiou
Hi does anyone have a modded bios for Z10PE-D16-WS which works? I have searched the thread before but all the links are dead and the people who posted them are non responsive.
Gordack
Hello, Could someone recommend me a good mainboard for E5-2680 v3 ?
I'm planning to buy this cpu. Can I able to unlock turbo on Asus or Gigabyte x99 boards ?
Scan409
27
22
41
Here is the mod
MUST USE efiflash 0.65_mod or 0.80_mod in DOS
ex) efiflash.exe [BIOS file]
GIGABYTE X99-UD5 WiFi : https://drive.google.com/file/d/1DC7te-6ZXO7ydcpSFZiyfJzv7M-n_QVk
efiflash 0.65 mod : https://drive.google.com/file/d/1jLAeWdsvIOPx5HCQvjIGb9vfPReKyLRl/
efiflash 0.80 mod : https://drive.google.com/file/d/1fQizIvfRjGbAnsN-HCZZ-iC-DyCEqZA8/
djthrottleboi
8
Here is the mod
What's the difference between the two? Also will tabbing work in efi flash. Im not used to flashing a mobo this way? Is it possible to use the emergency qflash thingy built in?
Scan409
27
22
41
Version 0.80 is the latest version of GIGABYTE efiflash Tool.
Support Intel 300 Series and AMD 500 Series Chipset Motherboard.
I recommend version 0.65, but you can use version 0.80 too.
In my experience, the GIGABYTE Q-FLASH function was unstable and buggy.
It was more stable to proceed with efiflash.
Last, I'm not using GIGABYTE Motherboard anymore. So I can't guarantee of this model.
Reactions: djthrottleboi
djthrottleboi
8
ok thanks
Reactions: Scan409
mikatone
I tried with a e5 2620v3 with One of my z10pa d8 and all goes well..
So the cpu under strees up ti 3.2 GHz.... Only a thing ,why does the RAM recognize ti 1833 instead 2133???? Is there some option to set this valute?
Hi, I'm using the exact same motherboard and CPU's! I was able to backup BIOS and flash it without EPROM programmer with help of afudos and free dos.
I've removed the microcode and injected driver v3_payne_0_0.ffs diabled CPU C6 report but unfortunately I can't go above 2.59Ghz. What am I missing?
