Originally posted by: spidey07
ccnp/ccdp, passed ccie written (failed lab
bunch of others I have since forgetten about like checkpoint and MCSE.
helped in that it helped me learn. I enjoyed the satisfaction that I could pass some of the harder tests (CCIE)
don't do much tech stuff now...more design and project management/management
haha..you failed the CCIE...c'mon man..it wasa Piece of cake
Seriously, congrats on at least being able to do the written. That lAB must be a bitch.
What do you have to do for it? Configure a MAN, WAN, and LAN for a major citty and businesses? Fix broken routers? solder?
The lab consists of building a network. The most convoluted, messy, hairy network you can imagine using only about 8 routers and 6 switches. And along the way you have to perform the tasks for different technologies, and they build upon the success of each other. And then later in the day - they break it...bad.
Then you must address each task for a particular technology like OSPF or BGP or Lan switching. The hard part is the tasks are nothing you would ever see in real life and purposefully make sure you understand the technology inside and out.
Example:
Task 1 out of 12 tasks in each section, around 7 sections on the exam. All in one day.
1) configure OSPF NSSA area using attached diagram. The OSPF backbone area will be broken...you cannot repair it or use virtual links. Ensure the NSSA area receives full routing information from broken backbone and all other areas along with the default. You cannot set default route or use default network command on any router.
time - 15 minutes.
It is truly nasty. The solution to this one was to build a tunnel, fix the backbone that way. Grab default route from BGP and inject into OSPF, tag it as E1 so that it could cross the NSSA boundary. Allow OSPF to propogate a default with "default information" command. But to even think along these lines you REALLY have to know your stuff. I just didn't know it well enough.
Would you EVER do this in the real world? Heck no. But in the CCIE lab, real world doesn't count.
