web designers, click here...
CasioTech
7,145
9
I was making a logo for my site, when I export it into flash, the background is noticibly different. Does something get lost in the process? I export the pics as...#333333 and they are a couple shades off my flash movie bg of #333333. Could this be corrected?
HERE.
...the DCD logo.
Josh
10,917
Sorry I can't answer your question, but flash is getting rediculous these days and I think a plain and simple website looks 10 times better.
CasioTech
7,145
9
I think it happens in html as well...so.
Scarpozzi
26,392
1,780
Maybe you should do all your logo design in Fireworks and that'll solve your problem...other than that, they may just have different swatches?
MrChad
13,507
Your Flash animation uses 40% CPU usage on a 3.0 GHz P4M. That's ridiculous.
nakedfrog
63,369
19,748
Check to see which pallette you're using, maybe. As in perceptual, custom, web, etc...
CasioTech
7,145
9
So, don't like it, close the window or disable the orbits.
MrChad
13,507
I presume that you're building a portfolio to showcase your talents to prospective customers. I wouldn't hire a developer who's website brought my year-old computer to its knees.
CasioTech
7,145
9
Omg my 4 y/o P3 runs it at 30fps....Your pc must be jakked up.
scorpmatt
7,040
98
site is also blocked here at work. but my suggestion would be to a preview upon export, also view the exported file before you put in the flash. you flash settings may also be messing with the picture colors.
Homerboy
30,890
5,001
That same design again? Man, everytime you post it you get lambasted over it.
There are Flash/HTML forums that would likely be better suited for your continued threads on this site design.
And yes, even on my AMD64 OCed to 2.8ghz your Flash is a resource hog.
CasioTech
7,145
9
I don't know what it could be, flash or PS?! imageshack is blocked where you work?
NikPreviousAcct
52,763
You totally missed the point.
You should be making flash games, not flash websites. you're very good with flash, but nobody likes flash websites with very few exceptions. Your work is not one of those exceptions :p
CasioTech
7,145
9
Yes, the same design, i'm making it better and better with each revision, and I don't know any other good forums.
Mo0o
24,227
flashkit
CasioTech
7,145
9
I've been looking into games, but haven't gotten into it.
CasioTech
7,145
9
flashkit
I'm a member and they suck.
scorpmatt
7,040
98
Yes, my work likes to block alot of sites, oh well. It is either your settings in your flash that is changing the picture or the export process from PS isn't going smoothly
CasioTech
7,145
9
flashkit
I don't get you ppl, there is a ORBITAL DISABLRE WHICH WILL RETURN THE CPU USAGE BACK TO NORMAL why don't you ppl use it?!
NikPreviousAcct
52,763
You need to. Your time would be much better spent designing something that people don't cringe at when they see. Not to say your skills aren't very good, because they are. It's just that people don't want to see an extremely complicated, CPU intensive website. They want something simple, elegant, and professional.
The sooner you get in to making flash games the better you'll be. Hell I'd venture to say that with a little more experience or classes or whatever, you could be doing things for major flash animation or flash game websites, possibly making money.
There's no money in flash websites.
Mo0o
24,227
flashkit
The default setting should be the optimum. I'm guessing most people dont want a geocities website clogging up their resources, thus the default setting should be OFF setting and not the "let's see how many cpu cycles i can rape from your computer" setting
Homerboy
30,890
5,001
There are more than 1, your google-fu is weak.
Not to mention you don't need a NEW THREAD everytime you make some microscopic change.... just update one of your exsistng 20 threads
