Originally posted by: SMOGZINN
Originally posted by: dahunan
Instead of always attacking the messenger why not THINK IT THROUGH..
Is it possible to control the weather
If we could intentionally heat parts of the ocean then would that affect the weather in that area.. but possibly have further reaching reactions
Okay, lets think it through.
Even if it was possible to generate enough heat in the ocean to generate a hurricane, there would be no way to guarantee that is would form into a hurricane and not just become a tropical wave. Then even if it did form, there would be no way to steer it. For a weapon to be effective you need to be able to aim it at your enemy.
Now let?s look at the first idea of putting enough energy in the ocean to generate a hurricane. Do you think that it could be done with no one noticing? What exactly would they use to generate that much heat? How would it be transferred to the ocean with out the entire world going OMFGWTFLASER!!!1!
If you had a device able to put out that type of heat, why not just hit your enemy with it directly?
