It has become obvious that you have decided you are all knowing on this subject. My 2006 article is "old" yet your 2008 article is a perfect example. The fact of the matter is that you keep throwing out arguments with minimal or no proof. There is a reason Nearline SAS drives exist. They simply SATA HDA's with SAS processor boards. You do this only to support SAS with out the overhead hit of SATA over SAS and to utilized the multipathing for redundant data paths. Otherwise they are cheap storage. SATA has moved heavily in to the Enterprise space for bulk storage. Not all Enterprise data needs to be on 15k RPM drives and the like. Not all enterprises require the extra heat output and needs of the SAS drives.
You may want to look at companies like google that run entire datacenters off of consumer sata drives because their own research shows that the enterprise drives rarely out last the consumer drives and that the failure rates are similar. These are the same servers where they found throwing multiple cheap consumer drives at a problem resulted in better over all performance than the cost to go enterprise. Facebook has a similar system. Except for some specialized SSD systems for certain database functions mostly uses consumer drives. They don't use things like RAID or ZFS.
Like it or not "the enterprise" is not locked in to SAS only. I have seen plenty of 300+ disk SATA EMC arrays in the wild. Pair that many spindles with a few "Enterprise SSD drives" which are purely "consumer drives" with the spare area shifted and you can attain amazing performance with quite a bit of capacity.
The other fun part: EMC, NetAPP, HP all format their SATA disks to 520 bytes on most of the "midlevel" storage solutions, Just like SAS drives with 520 byte sectors and do end to end error correction on SATA drives.
