blastingcap
- Sep 16, 2010
- 6,654
- 5
- 76
Well the only reason why you'd get long error recovery on a green drive is due to persistent read errors (internal to the disk). The problem is that it's non-obvious when this is happening until it gets really bad. If you're looking at the full SMART attributes rather than just the single pass/fail health attribute, you can see these show up in either the raw error read rate, ECC errors, or pending sector errors. Some system logs might also show read delays, not just a disk that reports back a read error. So you kinda have to do some diagnostics periodically and most people don't do that. They like to pretend the state of a diskW drive is binary: working vs not working.
So my suggestion is that you initiate ATA Enhanced Secure Erase on the drives periodically which will remove persistently bad sectors from use. You could also just zero the disk with a zeroing utility: this is easier for most people, but it's much slower, and it only zero's addressable sectors rather than all sectors. But if there are any bad sectors, it's equally effective at compelling the firmware to remove them from use, and substitute reserve sectors instead.
Thanks, I'm new to diy nas. I am building a raidz2 on nas4free. Do I even need to do the ashift 12 thing anymore or is the latest nas4free able to handle it? Or at least freenas0.7?
