Water Supply: Ocean
Aimster
16,129
Anyone know if this is being done or why it can't be done?
Is there not a way to purify the ocean water?
Was reading about the water shortage in parts of the U.S and was wondering if we can't just use the ocean's water and purify it and use it for drinking water. The only thing I could think of is that it is costly.
Please shed some light water experts.
Tobolo
3,697
Yes very expensive and then you also have to figure out how to get the water inland. For instance, Georgia needs water in the northern portion of the state. The cost to build a pipeline would be huge and you also have to figure how to get the water to flow up aprox 900ft (above see level near atlanta).
So, anyway, there are many reasons why.
soydios
2,708
The energy cost is huge, and it only works on the coast. They're considering it for coastal San Diego, but we've got a nuclear power plant twenty miles north of the proposed site.
91TTZ
14,374
You can't be serious. There's no way that you thought about this for more than a minute before posting, otherwise you would've found your answer anywhere you looked.
Wreckem
9,540
1,106
Its extremely expensive and inefficent.
Some middle eastern countries rely heavily on it but they have oil revenue to offset the costs.
gururu2
686
we would save so much water if we used sterile ocean water for toilets, showers and other non-drinking applications.
Sep 29, 2004
18,656
67
No current way to do it cheaply and quickly.
They do have plans for very large desalination plants. VERY large and expensive. Tey basically are large atriums that use condenation to their advantage. The condensation is then collected, making drinking water.
Aimster
16,129
I looked here and I found my answer.
techs
28,559
4
No can do. The salt would build up in a short while, clogging pipes, etc. Plus you can't really shower in salt water. Not unless you want to walk around with fine dusting of salt on you all day.
mrSHEiK124
11,488
You know, salty water would cause a lot of freakin problems in the shower.
iamwiz82
30,772
13
Have you ever been in the ocean? It does not make for good bathing water.
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
Originally posted by: MegaVovaN
If we had nuclear fission (safe/cheap reaction like on the Sun): http://en.wikipedia.org/wiki/Nuclear_fusion
, then we would have pretty much free energy and this would have been possible.
With regular nuclear fusion plants, energy costs are too high.
PSSST! You have it backwards. The sun uses fusion, current powerplants use fission.
ZV
bunnyfubbles
12,248
If we had nuclear fusion (safe/cheap reaction like on the Sun): http://en.wikipedia.org/wiki/Nuclear_fusion
Without regular nuclear fusion plants, energy costs are too high.
fixed?
I'd argue that fusion isn't necessary, fission is enough but with all the nuclearphobia that has plagued the U.S. for past few decades, getting new fission plants up and running any time soon is just about as optimistic as getting a profitable fusion reactor up and running within the next 50 years.
If we had gone full tilt nuclear (at least on the coasts) we could definitely do it and our only major worries then would most likely be how to deal with the brine (very salty sludge-like byproduct) pollution.
heyheybooboo
6,278
Kill Devil Hills (NC) Reverse Osmosis Desalination Water Plant
from 1999:
. . . major operating cost: the electricity used to generate the reverse osmosis (RO) pressure needed to push the feedwater through the RO membranes -- 2.981 kilowatt hours per thousand gallons (ptg) with cost of $0.134 ptg and the electrical cost is 30.5% of the total cost to produce the water...
Let's say that is around $.50 per 1000 gallons
Best info I can find on amortized capital costs (from 2003)
...future plants will be built at an average rate of $3.30 per 1,000 gallons...
From my short research the lifespan of the RO plants is shorter than that of a conventional water treatment plant and maintenance costs are higher - need to backwash the membranes frequently.
From direct seawater, recovery rates are around 40-45%; i.e., for every 100 gallons of seawater you get 40-45 gallons of potable drinking water.
The Kill Devil Hills plant uses brackish seawater and they claimed a 75% recovery rate.
